'71 B300 w/318 keeps stalling
Old May 30, 2014 | 03:00 PM
MorePar666's Avatar
Hello,
New to the forum, forgive me if this is a common question. I recently purchased a '71 B300 with a 318. I was able to drive the van home(less than a mile). Now, when I put it in gear, the van stalls. I can turn the engine over go about 5 feet and it stalls again. I had the trans flushed, changed the oil/air filters and the van idled for a good 20 mins after the service. Seemed good to go. I drove it around the block, then the issue happen again. Any ideas? Also. I'm fairly green at any DIY jobs, but I would at least like to have an idea of what's wrong. Thanks for help!
Old May 30, 2014 | 03:45 PM
I would check for vacuum leaks first, Check fuel pressure/ change fuel filter. Idle too slow ? Trans flush is ok but only does 1/2 the job
Old May 30, 2014 | 04:41 PM
Welcome.
Do you know how long it sat before you drove it?
I ask because this sounds like old car contaminated or clogged fuel system.
Old May 31, 2014 | 08:50 AM
when it stalls, does it peter out slowly or more like wham, it's off? could be electrical if you are running a mopar box.
heminate
Aug 18, 2019 03:06 PM
Skynyrd
Feb 8, 2015 08:31 AM
1337du0
13
Apr 17, 2014 06:17 AM
grease-monkey
Oct 23, 2011 01:16 PM
jar84203
Dec 25, 2010 04:19 AM
