93 dakota 5.9L 360 electric fan clearance issue
Old Apr 22, 2013 | 05:21 PM
TxDakota5.9's Avatar
as the title says I'm having clearance issues with an electric fan..I have a 5.9L 360 in my 93 dakota and im wanting to get rid of the clutch fan and install the mark 8 fans but I measured the fan at 5 1/2" and from the water pump pulley at 3" give or take...just from the fan to the middle of the fan motor was 3".. I'm sure I'm either going to have to stick with the clutch fan or find a smaller fan.
I guess what the main question I'm getting at is has anybody installed an electric fan if so which one... or if you have installed the mark 8 or taurus fan how did you do it...thinner radiator,different radiator,modify the grill to set the radiator closer to the front?
Old Apr 23, 2013 | 06:30 AM
PK1's Avatar
PK1
Ive done this and run this. Does your Dakota have the two core braces that attach just to each side of the hood latch?
You have to dump the clutch fan and the E helper fan if it has one. You have to shave all the extra plastic on the fan you purchased. You can bend the core braces and slide the mark fan in. It works great.
Use the trigger from the E helper fan to activate a signal for the new fan. You need to run a DAKOTA DIGITAL relay. The mark fan uses alot of juice. 40amps minimum.
If your fan has two speeds use the lower speed to start.
Old Apr 23, 2013 | 02:41 PM
I bought the truck with the swap already so I'm not sure exactly what your taking about... do you have any pics of your setup?
Old Apr 23, 2013 | 02:44 PM
Old Apr 23, 2013 | 05:33 PM
I'm gonna be running the hollister relay setup
Old Apr 24, 2013 | 05:49 AM
PK1's Avatar
PK1
That should fit with no issues. You need a clutch fan tool to remove the nut. But most places will loan it. Soak it good.
My set up is totally different than your so you are going to have to fabricate your mounts differently.
You will REALLY notice the difference getting rid of the mechanical fan.
Old Apr 24, 2013 | 09:13 AM
did you set the fan towards one side of the water pump pulley?..or directly in front of it
Old Apr 24, 2013 | 09:40 AM
PK1's Avatar
PK1
The shroud will limit where it goes. Get as much of the shroud covering the fins as you can. If it fits center than thats fine.
Mine is in an 01 and had plenty of room.
hckrphil
Jun 19, 2014 07:46 AM
B5Dart69
Apr 10, 2014 02:40 PM
440-4x4
Aug 14, 2011 04:46 PM
bigmanjb
Jan 11, 2011 02:41 PM
SixFoPolara
Aug 3, 2009 05:08 PM
