adjustable rockers
Old Apr 16, 2014 | 10:46 AM
wma1950's Avatar
adjustable rockers
Can anyone tell me which engines other than the 273 Hi Po and the 426 Race engines came with adjustable rockers? I have a set that I am putting on a built 383 and i would like to know what they came off of. Thanks
Old Apr 16, 2014 | 11:08 AM
Poly 318 ? for a 383 THEY ARE PROBABLY AFTERMARKET
Old Apr 16, 2014 | 05:17 PM
273 rockers certainly will not fit a 383 and neither will Poly. I don't know what might have come on the 413 / 426 wedges, but that would be my guess. No 383 that I'm aware of and certainly no 440 came factory with adjustable rockers
I once had a 426 "street wedge" and it had adjustable, but I don't know if it was factory.
Old Apr 16, 2014 | 07:50 PM
moe7404's Avatar
ill have to strain the old brain. so hang on. but i think some of the 300s with long rams had solid lifters, 413, early 60s. and my be the 57-58 300 392 hemi.
Old Apr 17, 2014 | 08:58 AM
wma1950's Avatar
I know the Max Wedge 426 phase III engines had adjustables on them and your right no 440 or 383 came with adjustables. I know these are Big block factory adjustables but there are no numbers on them. Oh well I guess I will have to special order some push rods because they take a cupped top push rod, $Ouch!!!!
Old Apr 17, 2014 | 09:35 AM
Also bear in mind this:
B engine pushrods are shorter than RB pushrods, AND
Hydraulic pushrods are different length than solid lifter pushrods regardless of B / RB
I'm going to use 273 adjustables on my LA "roller" block and when I get it further along hope to investigate shortening my old original 273 solid pushrods. If not I'll have to find some custom length. I don't have the info, some outfit named "Smith" was suggested for custom length.
Old Apr 17, 2014 | 09:36 AM
Are you Going to use Smith Bros. or Manton push rods ?
69POLARA383
Jun 26, 2012 05:31 PM
michuy
Feb 25, 2012 06:17 PM
Cudaparts
Oct 24, 2011 09:27 AM
moparjohnson123456
Jun 14, 2011 01:28 PM
Commando
Jan 7, 2009 07:20 AM
