Air Cleaner Upgrade?
Old 09-22-2014 | 02:39 PM
Robert Weaver's Avatar
Question Air Cleaner Upgrade?
Hi,
Does anyone know where I can find a upgraded Air Cleaner assembly for a 74 360 2bbl B Body Charger? I'm only using the PCV, Brake Booster & Dizzy for the emissions.
Old 09-22-2014 | 02:50 PM
Moroso From Summit...
Old 09-22-2014 | 02:54 PM
K, will any of those cleaners work? If I upgrade, won't I need a breather for the pass valve cover?
Old 09-22-2014 | 04:00 PM
Most of them will fit... Sometimes you might need an adapter to fit the air horn to air filter assembly..If you still want to run the breather to the Air Cleaner... You can Buy one of these..... http://www.jegs.com/p/Spectre/Spectr...42109/10002/-1 ... And install it... I think the Moroso's still have the knockout to use them.
Old 10-29-2014 | 09:22 AM
Are most of the upgraded cleaners 17in diameter, 4in carb area?
Old 10-29-2014 | 11:37 AM
A lot of them are 3" with a dropped base ! Depends on your hood clearance what will fit ?
Old 10-29-2014 | 03:20 PM
I've used one of these.
http://www.summitracing.com/int/parts/trd-2176
Old 10-29-2014 | 03:27 PM
Most common is a 14" Dia with a 3" element.
Old 10-29-2014 | 11:02 PM
moparted's Avatar
wont make any difference on a stock 2bbl small block, save ur money
Old 10-30-2014 | 04:14 AM
K but can I leave the vac hoses unplugged from the stock air cleaner except for the crankcase vent hose?
Old 10-30-2014 | 06:39 AM
You could... But it dose not help with the evacuation of the crankcase and its fumes without having it hooked up... You could also change it over to a chrome open breather in that case also. You could also get an air cleaner that has the breather hook up, or the capability of adding it.... Check out the Moroso Air cleaners for further understanding...
67gtxclone
04-01-2011 01:05 PM
jobberone
09-03-2009 09:34 AM
jobberone
08-06-2009 06:28 AM
BuckNeccid
11-03-2008 02:33 AM
mbridge1
01-28-2008 09:30 PM
Quick Reply: Air Cleaner Upgrade?
