Almost a back fire.
Old Jan 25, 2013 | 05:37 PM
raycan2's Avatar
Almost a back fire.
So we rebuilt the carb and the car is running good but has like a thump sound or feel, Its almost like its miss firing, We checked the spark plugs and the timeing on it and we get it close but its still their, Its almost like its missing or one cylinder not firing.
Old Jan 25, 2013 | 06:54 PM
Before I can try and help I must ask, is this the same engine with grooved and pin holed lifters that had one cylinder at 119 psi compression test?
Old Jan 25, 2013 | 08:43 PM
raycan2's Avatar
I think I found the problem, I checked the Compression on all 8 and got 119-121 psi,, The last spark plug I took out the gap on it was closed all the way..And yes its the same motor....I am learning as I go...
Old Jan 26, 2013 | 06:19 AM
Well done. You did most of what I would have suggested to locate your problem.
If your lifters a failing I would not run the engine anymore. All unfiltered oil goes through the pump first, very small metal can get through the filter sometimes. The obvious harm is the crank bearings but if the bearing siezes to the crank and spins the crank can be damaged beyond repair in the worse case.
deadkelly
17
Jun 12, 2011 04:27 PM
sgp7679
Mar 20, 2011 03:31 PM
IronmanofGod
Mar 6, 2010 08:35 PM
Muswagon
May 7, 2009 05:43 PM
ef8340
Aug 29, 2008 10:40 AM
