Blow-by and PCV
Old Apr 30, 2013 | 12:21 PM
Shrug's Avatar
Blow-by and PCV
OK my tired old Slant has some blow by. You can see the smoke coming from the breather. Not bad enough to stop driving, but it will need a rebuild by next year. Which is good because it will take that long to save up enough
Anyway The car has a PCV valve from the factory. It had the basic factory smog, with that weird adjustable thing for vacuum.
That part is busted so I am bypassing it.
I need to know if it is better to run the PCV line to the base of the carb or the line coming out of my intake manifold.
Old Apr 30, 2013 | 12:40 PM
Archer's Avatar
shrug -
If it's a full vacuum on the carb base (which it should be) the vacuum pressure will be the same on either.
Pick one.
Shrug
May 13, 2013 05:05 PM
dantheman
Oct 10, 2012 01:43 PM
fastdakota84
16
Jul 21, 2011 08:06 AM
1923tbucket
Apr 19, 2011 10:35 PM
67 Coronet
Nov 5, 2007 03:07 PM
