Bypass Interlock system question...
Old Dec 20, 2014 | 04:07 PM
Robert Weaver's Avatar
Question Bypass Interlock system question...
To bypass the interlock system on my 74 charger, do I just cut and splice together the 2 yellow wires from the connector going to the reset box?
Old Dec 20, 2014 | 05:19 PM
The one for the seat belt interlock is under the dash I thought?
Jump these 2 wires (Yellow & Yellow with black strip) and see if it starts.....
Old Dec 21, 2014 | 09:23 AM
K, I know there's a box under the glove box i believe but can you cut & splice the 2 wires together at the Reset box under the hood?
Old Dec 21, 2014 | 12:12 PM
You Could I suppose.... But why not just use a jumper wire and check it first? Unless your sure that the problem?
We are talking about this switch under the hood? Correct?
http://www.allpar.com/fix/electrical/interlocks.html
Mine was in good working order... Mine had a problem in the box under the dash. After I jumped the box under the dash. All was good.. Just dont forget about it....
Old Dec 21, 2014 | 04:14 PM
moparted's Avatar
easier to just run a new wire from the neutral safety switch to the starter relay
buttton
Oct 25, 2014 03:00 PM
Robert Weaver
Oct 24, 2014 10:11 AM
74Runneer
Jul 30, 2013 07:45 AM
kidcoolbreeze
May 28, 2007 01:35 PM
72swinger
Nov 23, 2006 08:19 PM
