Can I increase a lot of horsepower by straight piping?
Old Sep 9, 2019 | 06:50 AM
ilikevans's Avatar
My 1986 Dodge Ram Van's 5.9L only produces ~150hp right now and when I looked the engine up, they're supposed to make 245hp, but emission standards made it drop a lot, so I think they added really restrictive cats (and mufflers maybe). So, if I remove these or replace them with high flowing ones, will it come close to 245hp?
Old Sep 9, 2019 | 07:39 AM
In a word? No. not even close. Straight pipes *might* net you 10 hp. The biggest problem on these engines are the heads. You can't get power from junk heads. Rework or swap those and add a torquey cam and you'll be much closer to in business.
Old Sep 9, 2019 | 10:55 AM
NO
Old Sep 9, 2019 | 02:15 PM
NO
Could you be more clear, not sure i understand what your saying. ��
Strait pipes over an exhaust system with mufflers doesn't make more power, a stock motor needs a certain amount of back pressure to make torque and torque is what moves the vehicle.
I've actually seen this on the engine dyno, a restriction was put in the exhaust after the dyno headers and the power levels went up.
Old Sep 10, 2019 | 06:00 AM
Archer's Avatar
i -
What Skwerly said.
About the HP: are you looking at HP numbers at the rear wheels vs HP at the flywheel? That might account for your difference.
Old Sep 12, 2019 | 02:56 AM
Your just not going to gain that kind of H.P. by removing the exhaust on a stock van.... I just answered the question.
Old Sep 12, 2019 | 05:52 AM
Archer's Avatar
Bob -
This is the internet, you're not going to cloud the issue with facts, are you?
Guys -
Exhaust "restriction" may be the wrong word. There's an optimal exhaust cross-section per exhaust volume that allows an efficient rate of gas flow. That's why they make different diameter header primary tubes and exhaust pipes. A 2" exhaust on a 150 HP engine might be too big, and on a 500 HP engine, too small.
Think Bernoulli principle.
Old Sep 12, 2019 | 11:23 AM
Bob -
Oh, I see. It needs.... Ummmmmmm .... Ya !>>>>>>>>>It needs More Sugar.... ( Back when i was known as "Smokey Stratton" :Ya you know, Just like Smokey Yunick, but with lawnmower engines) I use to........ Oh never mind !!!!!
Come on guy's, You really dont think your going to make a 95HP gain JUST by putting a straight pipe on a all stock old Ram Van?
:::::: ok let me rephrase that:::::: Not going to Happen:::::
Just my 2 cents !!!!!!
If you do, do this, Please share the results. Fun topic, Thank you for asking the question.
74Charger73Dart
23
Mar 13, 2014 06:16 PM
HonkyCat
16
Nov 14, 2012 05:08 AM
Nightmare
Jun 18, 2012 03:23 PM
Jbalz
Oct 3, 2011 11:51 PM
BlueSmoothie
Aug 22, 2009 11:55 PM
