Which Carb?
Old Jan 19, 2013 | 12:11 PM
raycan2's Avatar
Which Carb?
I have a 440 in my 68 Coronet and have a 1405 Ebelbrock carb in it, Now being that it is a 600-650 cfm I was told I was starving the motor from fuel and air, Should I go with a Edelbrock carb different size or maybe like a Barry Grant street or speed Demon?
Old Jan 19, 2013 | 02:12 PM
todd383's Avatar
Depends on your motor specs,ported heads, cam size, compression, etc,etc, if its fairly stock, i think that carb should be fine. If motor is modified, a bigger carb like a 800 thunder series,or holley 750 or 800 dp, it will add about 6-10 horse power on top.
Old Jan 19, 2013 | 07:17 PM
Mr.4spd's Avatar
It would probably make more top end with a 750, but if you're happy with it as-is I would leave it alone. I'll bet the throttle response and fuel mileage is pretty good right now. There's always gonna be some a-hole in a minivan telling you how your car should be built...except he's in a minivan.
Old Jan 19, 2013 | 09:39 PM
Archer's Avatar
ray -
Pretty much what todd said, but I know a few fairly stout 440s running that cfm carb, usually Holleys though. Doubt I'd go over 750, unless there's been a lot of work done to the engine. Also remember that cfm by itself isn't whole story.
For giggles, I'd probably go with a bigger (and better) air cleaner though. Would look better and might improve air flow.
rcknrolfender79
Sep 1, 2015 07:42 PM
northcoasttip
Sep 26, 2011 11:23 PM
mopar777
May 3, 2011 07:26 PM
Valcam
Jun 4, 2009 11:47 PM
Doc
Jul 6, 2008 11:10 PM
