Carb Size
peterparr, tell us more about your combo, car weight?,cam?,tranny?,rear end gear ratio?,tire?,street or strip? it all depends on all those factors.
john
Only on a full out racer is a larger carb (900CFM or larger) needed.
This month in "Mopar Muscle" magazine, there is an article regarding carb sizing for a mild 383 that they've been working on.
They used Holleys from 650-cfm to 1050-cfm and got the best results with an 850-cfm #4781 Non-HP with mechanical secondaries....
The article also stated that the "most dramatic" increase was when they went from a 650-cfm to a 750-cfm.
I was disappointed that they didn't do a base line test with a Carter AFB or AVS.
peter -
Like the other guys are saying - depends on what's been done to the engine and the purpose of the car.
IIRC Holley recommends about a 650 for a stock/mild street 440 and 850 for a more aggressive race engine.
That being said, my 440 has a bit of work to it (rated a little over 500 HP) and really woke up on the track going from a 750 vac to an 850 DP. The 850 has been on the engine for about 30 years. These days, since I don't race anymore, probably should go smaller, but it still works - so I'll keep it for the time being.
Check Holley's website, I believe they have a cfm calculator.
Did a quicky check on Holley.com and not knowing max rpm range i used 6000 and went thru the steps to get an answer according to Holley. suggested size was 750-870 cfm. And that was with out checking the 'race' button, just the street button.
So that being said, a 650 MAYBE a bit on the small side...
Eric -
Just curious, did you try playing with the jets and were you running the correct size power valve based on vacuum? Mine was running rich as well, until I dropped to a 5.5 PV (manifold vac was about 11 in gear, and the original PV was a 6.5).
Sorry, don't recall what jet size we ended up with.
Yes, the 4-hole spacer did make a noticeable difference in low end torque.
Monaco68
07-17-2011 11:27 PM
