Carb Size
Old May 4, 2012 | 03:47 PM
peterparr's Avatar
Carb Size
I have a couple buddies who disagree on carb size. I have a 650 Carter on a 440 engine. One says its fine one says too small. ANy comments?
Old May 4, 2012 | 03:51 PM
With a stock intake and stockish cam and such that's just about right. Might go to 600 cfm also.
Old May 4, 2012 | 04:11 PM
peterparr's Avatar
Other guy says I should go to an 850-seems maybe too much, right?
Old May 4, 2012 | 06:01 PM
fivepoint's Avatar
I have a 750 on a 440 with a mild cam and have considered going to a 650. Unless you have something real radical, 850 is way too much carb.
Old May 4, 2012 | 06:25 PM
My buddies 440 hp Belvedere 284 .484" purple shaft 4.10 gear and 4 speed had 800cfm double pump and was perfect on the street. Wicked little car.
Old May 4, 2012 | 06:42 PM
John Van's Avatar
peterparr, tell us more about your combo, car weight?,cam?,tranny?,rear end gear ratio?,tire?,street or strip? it all depends on all those factors.
john
Old May 4, 2012 | 06:57 PM
OldMechanik's Avatar
john
Indeed...a 600 would be fine on a grocery getter, where a built up high output engine would need more CFM. Keep in mind throttle bore size, a 750 holley style carb modified to flow more CFM would be a wise investment on the street vs. an 850 with larger bores. The smaller carb would deliver better street-abillity while flowing good at high RPM. A spreadbore style carb of 850 like a Thermoquad is a great performer on the street as well.
Only on a full out racer is a larger carb (900CFM or larger) needed.
Old May 4, 2012 | 07:16 PM
Silverick's Avatar
This month in "Mopar Muscle" magazine, there is an article regarding carb sizing for a mild 383 that they've been working on.
They used Holleys from 650-cfm to 1050-cfm and got the best results with an 850-cfm #4781 Non-HP with mechanical secondaries....
The article also stated that the "most dramatic" increase was when they went from a 650-cfm to a 750-cfm.
I was disappointed that they didn't do a base line test with a Carter AFB or AVS.
Old May 4, 2012 | 07:30 PM
Archer's Avatar
peter -
Like the other guys are saying - depends on what's been done to the engine and the purpose of the car.
IIRC Holley recommends about a 650 for a stock/mild street 440 and 850 for a more aggressive race engine.
That being said, my 440 has a bit of work to it (rated a little over 500 HP) and really woke up on the track going from a 750 vac to an 850 DP. The 850 has been on the engine for about 30 years. These days, since I don't race anymore, probably should go smaller, but it still works - so I'll keep it for the time being.
Check Holley's website, I believe they have a cfm calculator.
Old May 4, 2012 | 08:02 PM
You can read the specs on my 440 in my signature. I had a 870 Steet Avenger on it and it was too much. I jumped back to a 770 and it was much better.
Old May 4, 2012 | 10:27 PM
MrOldart2U's Avatar
Did a quicky check on Holley.com and not knowing max rpm range i used 6000 and went thru the steps to get an answer according to Holley. suggested size was 750-870 cfm. And that was with out checking the 'race' button, just the street button.
So that being said, a 650 MAYBE a bit on the small side...
Old May 5, 2012 | 02:10 PM
How so, just out of curiosity.
Old May 5, 2012 | 04:06 PM
It was too rich. If I had a 1" spacer or an air gap intake then maybe it would have worked. Try putting any kind of spacer or such on a 440 A body.
Old May 5, 2012 | 05:33 PM
Archer's Avatar
Eric -
Just curious, did you try playing with the jets and were you running the correct size power valve based on vacuum? Mine was running rich as well, until I dropped to a 5.5 PV (manifold vac was about 11 in gear, and the original PV was a 6.5).
Sorry, don't recall what jet size we ended up with.
Yes, the 4-hole spacer did make a noticeable difference in low end torque.
Reddo
Mar 15, 2015 06:28 PM
northcoasttip
Sep 26, 2011 11:23 PM
Monaco68
Jul 17, 2011 10:27 PM
72RDRNR
Nov 30, 2007 11:55 AM
cowvette
Mar 7, 2007 08:24 AM
