cc
Old Feb 25, 2012 | 01:21 AM
duster sweden's Avatar
cc
have someone have this xe295hl in your la360 ?
Old Feb 26, 2012 | 04:54 PM
PK1's Avatar
PK1
Thats alot of cam.... Whats your set up?
Old Feb 26, 2012 | 07:26 PM
yeaaaa, that cam is HUGE. i hope you have real hot heads. haha, hot heads.
Old Mar 1, 2012 | 05:14 PM
my set up..ported rpm heads, rpm airgap, holley 750 wacuum, 10.7 cr, headers
Old Mar 3, 2012 | 05:52 PM
scotts74birds's Avatar
It doesn't sound very street-friendly. Unless you have a very "loose" convertor, and some high gears. I say this 'cause I "over-cammed" a motor once. No fun around town, terrible part-throttle performance under 3500 rpm, un-tuneable at idle.
Old Mar 3, 2012 | 06:11 PM
PK1's Avatar
PK1
Your CR is good and your Eddies if ported correctly should feed it. Its a pro street cam or bracket class.
Your usable rpm will be above 6500 rpm. The Eddie springs wont work. You will need a hefty triple to handle the pressures. Forged rotating assemble and keep the bob weight down.
This strickly a 1/4 mile ride?
Old Mar 13, 2012 | 05:00 AM
street killer
here we have street/drag race, so this is a car for weekend fun..
Old Mar 13, 2012 | 07:35 AM
PK1's Avatar
PK1
I can tell you from personal experience that 230/236 XE series cam cut with valve lift in the .56 area with an Eddy head will net 450HP right around 5900 rpm. Nothing radical here. Nice torque curve too. Idled decent and could be street driven, but not a daily driver IMO. It needed a single plane and a lg header.. but very responsive motor..
Going up from there will yield a slight power increase and higher peaks but you lose bottom and lower mid range and your curve area of power is shifted with no net average gain.
If you need more power AND want that street use, redo the bottom end and throw some nitrous at it.
Old Mar 13, 2012 | 01:21 PM
i go for 100 hp nitroz and hope i dont blow my engine out..all to be a winner at summer weekend, but for this summer night i race with my lunati 60404 cam and rpm intake..next winter i step upp with my xe295hl and a singel plane, 2 cams ,buy i when i import the car and all the stuff..so i have much of things to build a real "killer"..just the parts to built my engine cost me 9000$, my gears is 3.91 and i going to buy a 3500rpm converter here ower..it's not cheap things, aubout 1500$..10 inch..just to buy..
