Chrysler '95 ECU, engine computer, ignition glitching
Old Apr 1, 2015 | 08:06 PM
dbossev's Avatar
I got some intermittent problems with with my Chrysler Cirrus '95, V6. The ignition signal from the engine computer (ECU) to the distributor seem to be glitching and causing the engine to hiccup. This happens only when the ECU gets hot. Friend of mine speculated that this is a faulty electrolytic capacitor in the ECU. There are 3 of them visible under the semitransparent potting gel. Does anyone know which one (of the three) is connected to the ignition circuit in the ECU? I believe that similar ECUs were used in Clouds, Neons and minivans in 1994-2000.
Old Apr 2, 2015 | 06:21 PM
moe7404's Avatar
the dist coil can be tested by measuring the OHM. an other way i figured out. use an anlog meter. set the meter to the lowest A / C setting. put the meter probes in the wires coming from the dist, order is not important. the spin the dist. the meter should show movement if dist is good. you can even have the dist out of the engine. the meter may not move much.
Old Apr 3, 2015 | 09:28 AM
dbossev's Avatar
The distributor is OK. I just replaced it. I also dug the electrolyte capacitors from the ECU (PCM) and will replace all three of them. I need to buy hi-temp capacitors (>125C).
felipec2106
Dec 4, 2014 03:09 PM
RacerHog
Nov 16, 2013 10:51 AM
66belvkm
Jun 29, 2013 07:04 PM
440GTXguy
Apr 20, 2013 10:14 PM
dsmtuned
Jun 3, 2009 07:06 AM
