CLEANING out a fuel tank...
Old Oct 9, 2011 | 12:19 PM
lookingatchargers's Avatar
Whats the best way/approach to cleaning out a fuel tank of a 72 charger? Is it possible to to dump some chemicals in there and let it run or will I have to take apart the tank and clean it that way?
Old Oct 10, 2011 | 05:36 AM
JS23's Avatar
Check with Eastwood
They have some cleaning agent and sealant.
Old Oct 10, 2011 | 08:32 AM
Originally Posted by JS23
Check with Eastwood
copy that...thanks
Old Oct 11, 2011 | 05:55 PM
scotts74birds's Avatar
In a larger city, check some of the rad places. They also do that. Might not help, but give it a try
Old Mar 9, 2012 | 01:34 PM
Justin Ward's Avatar
CLR and pitrun I was told but I didnt like the idea of pitrun. I used about 2 galloons of CLR and 4 pcs of 2 foot small chain and swished it around i let it sit over night on one side then swished for hours here and there and let sit. I did this over 4 days and my tank was horrid when i droped it out, it is now nice and works great with no problems. Easy cheap and it works.
Old Mar 9, 2012 | 02:07 PM
PK1's Avatar
PK1
Use to do the same. CLR or something similar and old light weight stainless chain.Throw it in and place tank in the parts hauler. Drive for couple days and let it swish around.
I also like Eastwoods product too..
Good luck!
Old Mar 25, 2012 | 05:35 AM
bigsho's Avatar
I took the fuel tank for my 67 sport fury to a local radiator shop and they boiled it out and lined it. also patched a few pin holes they found. cost about half the price of a new tank. so you might try that option
Old Aug 29, 2012 | 03:04 AM
Isaac's Avatar
Smile
The inner bladder of the tanks can be easily detached, allowing you to clean and examine the center walls of the tank, and to be rest certain you are only drinking the cleanest consumption water possible. Additionally, the inner bladder of the tanks are a bit extra-large, so the pressure will not be exert on the interior, but rather on the sides of the tank, eliminate the possibility of rupturing or tearing the tanks.
Tank Cleaning services UAE
Old Aug 30, 2012 | 09:36 AM
moparted's Avatar
GET A NEW tank
Robert Weaver
Oct 4, 2014 03:50 PM
chykov's76doba
Sep 16, 2013 10:52 AM
74Runneer
May 8, 2013 02:02 PM
bremereric
Mar 22, 2012 01:02 PM
MagnumBlue
Jul 28, 2009 06:01 PM
