Cleaning the fuel tank
Old May 7, 2013 | 05:43 PM
74Runneer's Avatar
Im thinking that since my 74 roadrunner has been sitting for about 7 years that i should clean out the tank. Whenever I get low on gas the my engine starts to run crappy. Im not positive, but i think its from all the crap that may be on the bottom of the tank. So how hard is it to clean the tank, and what do i need to do to clean it?? Budget it tight so id like to spend as little as possible. What do you guys think??
Old May 8, 2013 | 12:34 PM
74Runneer's Avatar
Anyone???
Old May 8, 2013 | 01:50 PM
67hemidart's Avatar
I would think I would need to remove it drain it and see what comes out . Then if there is rust in it replace it if just crud I would put more gas in it swish it around and dump till clean hope this helps
Old May 8, 2013 | 02:02 PM
74Runneer's Avatar
Okay ill try that, Thanks!
Robert Weaver
Oct 4, 2014 03:50 PM
chykov's76doba
Sep 16, 2013 10:52 AM
lookingatchargers
Aug 30, 2012 09:36 AM
bremereric
Mar 22, 2012 01:02 PM
MagnumBlue
Jul 28, 2009 06:01 PM
