clear rad hose
Why???? they do make a clear thermostat housing so you can see the stat.... I have never heard of a filter or a clear hose unless it was for a milking machine
... You crack me up Moe...
<you
<me...Bill
<you
<me...Bill
You could look into Porous Ceramic Membrane, good to 1000 degrees C. It will be quite large, maybe 12 inch diameter would do.
Hose is a problem as I've only seen it up to 150, maybe 180 degrees F. All the hose we use on steamers is not clear.
You'll need a Booster pump as the stock one won't generate enough pressure to push through the additional piping and the filter. I would suggest a Commercial Dishwasher pump from a Hobart K series with metal housing, most of the Jackson, Champion and MDL's are using plastic housings now which probably won't hold up, stay away from Jet Tech they are junk.
I think it is doable and would fit nicely in the back seat or trunk if you want to maintain passenger space.
All you need is a flux capacitor and a nemron pump to push the fluid through the miles of piping it will require to cool the coolant down enough to put a clear hose from a dish washer(specifically the one from the Hobart K series) on your truck..
LMFAO...Looks like your on your own on this one Moe....Bill
Hey Bill, I sell milking machines but have never heard of a cow giving milk that hot!!! It would be self pasteurized and save a step at the dairy.... The hoses we use would not stand the pressures or the temps!!! Good idea,,, And that is thinking out of the box for sure!!!
. He is always thinking... A few weeks ago he wanted a in line transmission filter with magnet (which they make) now he wants a coolant filter...Why??? the problem with coolant is not dirt but electrolysis that breaks it down...And a clear hose... Why??? To see the coolant going to the radiator???? On a V6 Dakota??... Bill
oke: I would love to see the clear hose and where it can be purchased.... I am always up for learning about something new... I like to learn something new every day... Peace brother... Bill
poking fun at me is fine. on a radio control site that i go to we poke fun at one guy about not wearing pants. it gets very funny. i made up a saying about me being a red neck.
"I am the west side red neck. Iam old, cantankerous, bias, prejudice, and I dont suffer fools or idiots. Get over it"
got to go i need a nap.
stazja01
May 27, 2009 03:43 PM
