Cracked Ear
Old 11-18-2011 | 09:16 PM
Slice's Avatar
Cracked Ear
Major F-up. Just finished building 500 stroker for my 1970 Coronet R/T and I cracked the passanger side rear mounting lobe on the block. I had the crack welded, but I don't trust it and would like any suggestions on alternate mounting points and any pics would be great. I dont want a mounting plate or elaphant ears. I'd prefer to run a rod with a bushing from somewhere else on the block. I never saw this done, but if anyone out there has, I'd love to hear about it.
Thanks
Old 11-18-2011 | 10:04 PM
DId you break the locating dowel off ? or just the end ? If a proper weld was done it should be fine, Not sure on the 440's it's been many years since I worked on one, If they are like the LA motors there is a reinforcement From the side of the block to the trans. should be sufficient
Old 11-18-2011 | 10:40 PM
Slice's Avatar
The pasenger rear ear on the block. There are 3 that the motor mount bolts to. 2 on the top and 1 on the bottom front. Someone arc welded the crack, but I don't trust the weld. It will probably be fine, but I hate building a stronger motor and then having weaker mounts, so I'm looking for an overkill solution so I don't have to worry about it..
Old 11-19-2011 | 06:41 AM
maddawg57's Avatar
If your still worried give these a try I run them on my stroker.
'63-66 A-Body Torque Strap
'67 & Up A-Body Torque Strap
'62-65 B-Body Torque Strap
'66-72 B, '70-74 E-Body Torque Strap
Adjustable Torque Strap
STOP ENGINE MOVEMENT!
• Features heavy duty rod-ends for adjustability, urethane bushings, DOM tubing, grade 8 fasteners
• Works with power steering
• Installs easily, with no welding or major fabrication required
• Complete kit includes: powder-coated torque bracket, all necessary bolts and instructions
For Small Block & B/RB (does not work with Hemi):
'63 & Up A-Body
'63-72 B-Body
'70-74 E-Body
(shown as installed)
Throw away your chains and broken motor mounts; our new torque strap can handle all the upgraded power and excess vibration your A-Body small block engine can dish out. Mounts in existing sway bar location on some models.
(see instructions and installation photos)
TQ63A - $79 + $15 S&H
small block or B/RB engine can dish out. Mounts in existing sway bar location on some models.
TQA - $79 + $15 S&H
Throw away your chains and broken motor mounts; our new torque strap can handle all the upgraded power and excess vibration your B-Body small block or B/RB engine can dish out. Mounts in existing sway bar location on some models.
TQ63B - $79 + $15 S&H
NEW B & E-Body C-shaped bracket! Revised bracket now sold with all B & E-Body Torque straps.
(see revised bracket instructions and installation photos)
TQBE - $79 + $15 S&H
Engine Swaps Newsletter
Sign up to receive news, announcements and new product information by email
Email Address:
Schumacher Creative Services ©2010
Old 11-19-2011 | 09:02 AM
John Van's Avatar
Slice,since it's the right side,I wouldn't worry about it. The left side mount takes all the abuse.
john
Old 11-19-2011 | 01:30 PM
Slice's Avatar
Has anyone seen the schumacher torque strap on the passanger side??
Old 11-19-2011 | 03:01 PM
maddawg57's Avatar
yes I have them on both sides
Old 11-20-2011 | 09:57 PM
Slice's Avatar
I'm getting an overwhelming response not to worry about it, but I may throw a strap on ( a torque strap that is) on both sides anyway.
Old 11-21-2011 | 02:09 PM
John Van's Avatar
Slice,The torque straps are nice,got one on my cuda.I would also get a polyurethane transmission mount,it keeps the tranny from twisting too much.
john
Live Wire
10-07-2010 10:00 PM
RROriginals
05-17-2010 07:44 PM
79woodnick
04-27-2010 09:55 PM
unclemike
10-11-2007 07:31 PM
ProEmaster
03-01-2007 01:19 PM
