crankcase ventilation
Will a valve cover breather cap be sufficient without a pcv valve or is the pcv valve a necessity ? My valve covers are not drilled for a pcv valve or oil fill cap or a breather cap just wondering if I need to make 3 holes or try to get by with 2
PVC= polyvinyl chloride, as in plastic commonly used in plumbing pipes
PCV= positive crankcase ventilation, as in the small one way valve commonly found on internal combustion engines.
Kick me in the nuts for correcting you, I deserve it.
If you have at least 2 breathers and are going to pull one to fill oil you will be fine.
OR
Mopar makes a breather kit that allows you to run heater hose to the breather and then place a bung down stream in the exhaust and vent the fumes. This HELPS ALOT with the smell.
OR
With two cut outs a PCV valve can be added and the other breather will serve as the intake air hole to equalize pressure and oil fill.
OR
OR
I started with one Breather and a PCV...but after Running high rpms the dipstick would pop out of the tube so i added a second breather and that fixed the problem.
i drilled a hole for the pcv and used the two existing oil fill cap holes for pushin type breathers.
So far as the question, I do NOT like to "not" run PCV. But be carefull where you head. If you just punch a hole in the cover and slap a PCV in there, you just might be "suckin' oil." A PCV should have a baffle of some sort.
You cannot buy the "nice" ones anymore, but I use the Ford type breathers used on the late 60's --70's Ford products. These are a big breather, which fits "twist in" bayonet filler holes, and take a grommet in the top.
I have one of these on both valve covers. You can put a PCV in one breather, and an open breather hose on the other. This hose is normally routed to the bonnet on the air filter.
However, I "Cheat" a little on mine. I have an older set of Cal Custom VC that I've actually had since the '70's!!! These have a twist lock filler on each cover, as well as a spot for a PCV.
So on mine, I have a "Ford" style breather on each VC, with a 5/8 hose down to the bottom like a draft tube, and a PCV in one cover. This seems to work well.
If you have two breathers and a pvc, and your still blowing the dip stick. Your problem is blow by,, Rings is your only cure. If you run a pvc, with twist on oil caps with no breather it creates a vacuum and screws your rings up.. Learned this lesson on the first engine I ever built.. I hate any valve covers without baffles, they are messy from oil that gets slung up in the breathers and pvc.
Their is a half moon cure for valve covers with no baffles, They do make a baffled rubber grommet that the pvc or brether will fit into.
Links
http://www.summitracing.com/parts/mrg-5425
http://www.summitracing.com/parts/sum-g3413
Links
After two Breathers ...and i had to make the baffles at least they gave me precast holes to tap for them but since i installed the second i haven't had the dipstick pop i've run her to 6500, i think i got the ventilation of the crank case more than adequate.
