Drilling/tapping intake manifold for vacuum port?
Old Mar 27, 2013 | 02:10 PM
98 SNAKE EATER's Avatar
Question Drilling/tapping intake manifold for vacuum port?
My '69 RR has a Team G intake and a Demon Dominator carb.
Hood clearance is a bit of a problem, so it's been running without an air cleaner since it was built
After some quick measurements, I figured I could ditch the 1" carb spacer to make some room for a custom air cleaner
Pulled the carb to rebuild over the weekend and realized the spacer had the only vacuum port
So now the plan is to drill and tap the intake for a vacuum port, but after eyeballing the intake, the front and rear walls look to be much thicker than the sidewalls
They're also curved whereas the sides are flat.
I've always seen ports tapped into the front or rear of race intakes, but would I have any issue tapping into the sidewall?
I figure vacuum is vacuum, right?
Old Mar 27, 2013 | 06:13 PM
jacilynn_s's Avatar
Id be too afraid that there would be an imbalance issue from taping into the sidewall. if this is an aluminum intake I would suggest using wax to drill and tap the hole.
Old Mar 27, 2013 | 07:13 PM
PK1's Avatar
PK1
Ive drilled and tapped with out issue. I always made sure there wasnt any protrusion into the intake.
Old Mar 27, 2013 | 07:25 PM
Have you done it to the sidewall?
The actual drilling and tapping isn't an issue as I've done plenty of hidden fogger kits, but I've never really done a lopsided vacuum port before
Keep in mind this will be used for PCV, so I'm curious if an imbalance of oil vapor being plumbed into only one side might cause an issue
Old Mar 27, 2013 | 08:24 PM
See where the V shape is right below the spacer. I would drill and tap the hole right in the center of the V in the back.
Old Mar 28, 2013 | 03:13 AM
PK1's Avatar
PK1
I would tap the front or back. The curve wont come into play since the wall is thick enough to get sufficient thread.
Old Mar 28, 2013 | 04:49 AM
bigblock's Avatar
It don't matter where you put it. Prolly never has vac anyway.LOL
74Runneer
May 22, 2013 05:01 PM
rottenleonard
Sep 9, 2012 08:53 PM
Barfly
Apr 17, 2011 09:15 AM
1923tbucket
Jun 22, 2010 09:14 AM
M1 Manifold
May 21, 2009 02:23 PM
