EGR Valve stem not closing all the way
Old Jul 22, 2020 | 08:45 AM
jm2576's Avatar
How tight should the valve stem be on the EGR valve? Is it supposed to be air tight? My engine idles low and I have low vacuum. While I was looking for a vacuum leak, I sprayed carb cleaner a the base of the valve stem on the EGR valve and the idle and vacuum jumped up. I can see the valve open and close properly when I increase the RPM, so I know the valve is working properly, but I suspect the valve stem may not be seating properly.
XMANJR
Jun 7, 2019 04:43 AM
josehf34
Mar 8, 2014 08:26 AM
Manoharvalves
Sep 15, 2011 10:53 PM
Slice
Jan 24, 2010 02:24 PM
CAT-TECH
Jan 30, 2008 08:46 PM
