Exhaust manifolds
Old 09-08-2021 | 05:55 PM
Ashton1012's Avatar
Exhaust manifolds
Hey everyone!
ive been working on tackling an exhaust leak on a 1977 dodge 360. Pulled the passenger side manifold and found it is warped. I dropped it at a machine shop today, but they said they weren’t sure if they’d be able to mill it flat without taking to much off.
as a back up plan, has anyone found a quality aftermarket replacement with the heat riser? There isn’t much availability of used parts, so new might be my best bet. Thanks for any help you can provide.
Old 09-09-2021 | 09:46 AM
Ashton1012's Avatar
Well, got the call. The manifold is to far gone. So I’ll definitely need a replacement! Any advice?
Old 09-09-2021 | 08:25 PM
I have a pair, what state are you in?
Old 09-09-2021 | 09:54 PM
Ashton1012's Avatar
Goldendale Washington
Old 09-09-2021 | 09:55 PM
Ashton1012's Avatar
I’ve found some reasonably priced aftermarket replacements, but they don’t have a heat riser. Sounds like I’d be ok going that route but was wondering if anyone else has deleted their heat riser?
Old 09-10-2021 | 02:20 AM
It would be a little cold blooded but something you could live with.
I put headers on when my truck was 9 years old and ran it for 25 years without the heat riser or heat in the intake at all.
Old 09-10-2021 | 12:18 PM
Ashton1012's Avatar
Fortunately I don’t really use it in the winter because it’s in an RV! So I suspect it won’t cause to much issue for me.
I was able to find some Dorman manifolds at autozone. I haven’t bought them yet because they look kind of cheap. I can’t find much for reviews so I supposed I’ll just have to try them out and see how they do!
Old 09-11-2021 | 12:27 AM
Ashton1012's Avatar
Ok I’m back for more help!
I went to four parts stores today and no one could even order manifolds. When I search online there appears to be options, but the manifolds are slightly different that the ones I have. Below each large hole is smaller holes; on my current manifolds that does not exist it is solid metal. I can’t seem to find any that don’t have those extra holes. What is the purpose of these holes?
Here’s a link to some to help understand what I mean.
https://www.rollingautomotiveparts.c...enger-side-new
Old 09-11-2021 | 01:00 PM
Ashton1012's Avatar
Another update in case somewhat smarter than me chimes in! Though I may have my answer before then.
I was finally able to source the part (I think). The problem is that every website I look on, the passenger side manifold which is the one I need, shows a flat/flush surface on the flange. The one I just pulled off has a protruding surface, which is exactly what all the drivers side manifolds I find online look like. If you are curious what I’m talking about, compare Dorman part number 674-234 to 674-233. I went ahead and ordered the drivers side even though I need a passenger side. I am hoping I made the right choice. I won’t know until Thursday when I have the part though.
Old 09-14-2021 | 08:40 AM
The lower holes are for the air injection emission air pump holes....
Some of the exhaust flanges had the beveled flange and some came with a flat flange. The flat one you have to use a gasket with.
Old 09-21-2021 | 09:52 AM
scot426Mw's Avatar
do you have a picture of your old one? I have a SBM right exhaust manifold you can have, if it is the same.
~a
rockdog2112
12-04-2014 11:06 PM
Dave E
13
03-10-2014 01:06 PM
QuaZi ET Gremlin
08-15-2013 04:33 PM
edemestihas
06-06-2013 02:40 AM
Drakovich
04-03-2011 08:29 PM
Quick Reply: Exhaust manifolds
