EXHAUST TOO LOUD
Old 08-06-2015 | 07:31 PM
Magoo's Avatar
Question EXHAUST TOO LOUD
On my 69 Valiant with a 360/408, with 3" TTI exhaust, I originally had 3" Cherry Bomb Turbo mufflers, from Summit. In an effort to lessen the noise, while cruising, I switched to 40 Series Flow Masters. -- For those of you who know, obviously I went in the wrong direction. The Flow Masters are louder than the Turbos. -- Now the question -- Any suggestions on what muffler to use ? I still want to stay with 3" mufflers to match up with the current pipes. I realize that I probably will sacrifice some performance as I go to quieter mufflers, but that's not a major concern of mine. -- This is currently a Street Cruiser, not a Drag Car. -- Worst case or possibly best choice, I can go back to the Turbos. -- Thanks
Old 08-06-2015 | 09:30 PM
USE BOTH the turbo and Flowmaster if there is room
Old 08-07-2015 | 04:45 AM
Magoo's Avatar
There's room but that would be a little cluttered, and not very neat. - I guess, that I want my cake and eat it too.
Old 08-07-2015 | 08:17 AM
Magoo's Avatar
Unhappy Back to Turbos
From a cost standpoint, I'll probably just put the Turbos back on, and eat the Flowmasters
Old 08-07-2015 | 03:36 PM
moe7404's Avatar
get your muffler man to make the last 2- 3 inches of the pipe 20 to 30% smaller than the main pipe. not much more restriction but will reduce the noise.
Magoo (08-07-2015)
Old 08-07-2015 | 05:42 PM
Add a Resonator to the system... That should cut the DB by about 10% to 20% or there about.... Or Look into the Spin Tech muffler.... You might need something with like 3 baffles.... Just my 2 cents....
Magoo (08-07-2015)
Old 08-07-2015 | 08:52 PM
Rooty's Avatar
Had the same issue with Flowmaster 40's. I have TTI's as well and the noise was overwhelming. Bought a set of Borla's from Summit and problem solved. They fit right in place of the Flowmaster's with out changing anything on the exhaust system. Borla's can also be reversed ( installed in either direction ) so there's no definitive "in" or "out". The sound is really pleasing.
Magoo (08-08-2015)
Old 08-08-2015 | 04:20 AM
Magoo's Avatar
Unhappy
I definitely have to take the Flowmasters off. I drove to a cruise 20 miles from our town, last night, and I can't stand the sound. The car will be parked until I switch them out with something. -- Do you have a 3" system ? - What motor ? - Which Borla did you get ? - P/N 40359 looks good. -- Thanks
Old 08-10-2015 | 04:17 PM
moparted's Avatar
I doubt on any a body has room for 2 mufflers or a muffler and resonator. any 3 inch system with be loud. I have the sumit 3 inch system on my dart with a 318 . its louder than my 440 challngr with a 2.5 inch system
Old 08-10-2015 | 05:43 PM
moe7404's Avatar
yep i think bob is right the newer mufflers are very good. i am just going to stay stock from now on. i built a muffler from scratch one time. for a slant 6. large otter tube with a small er inner tube. with the inner tube held to the outter tube at the end sliding on to it. and take out bolts and remover the inner tube for just a large out let.
Old 08-10-2015 | 07:59 PM
Magoo's Avatar
Smile Getting Older
-- Yep -- 3" systems are loud. I've had both 2-1/2" and 3"systems with Flowmasters before -- BUT -- I was 20 to 30 years younger, and thought that it was "cool".
Old 08-20-2015 | 11:00 AM
Magoo's Avatar
Thumbs up FLOW MASTERS ARE GONE
I took the Flow Masters off and put the "Cherry Bomb Turbos" back on. They have a nice sound, but are much quieter, especially at cruising speeds of 50 - 60 MPH.
Old 08-21-2015 | 07:28 AM
Cool... Thanks for the update.... Good you found something you can live with...
I need to do a Brand-X soon... Might just go that route...
Old 08-22-2015 | 08:29 AM
Archer's Avatar
Magoo -
The 40 series FM are the loudest they make, IIRC. You can either try the Magna Flows (use the biggest ones that have your I/O configuration) or get a pair of stock Walker Hemi mufflers. That's what I'm using, and while not dead silent, quieter and with a slightly more "Stock" sound. When you're racing, they're coming off anyway, right?
Old 08-22-2015 | 01:25 PM
Magoo's Avatar
Smile
Originally Posted by Archer
Magoo -
I'm satisfied with the Turbos. -- Since racing is in my past, this car is just a "Toy".
moe7404
02-25-2014 07:38 PM
67hemidart
04-26-2012 08:18 PM
DartConvertible
03-17-2008 06:22 PM
theaspenator
02-01-2008 08:46 PM
ucfierocharger
11-20-2007 08:16 AM
Quick Reply: EXHAUST TOO LOUD
