Head milling
Old Nov 8, 2014 | 07:26 PM
440 aspen's Avatar
Head milling
I have 452s on a low comp 440. I don't have the money to do a piston swap so I was thinking about having the heads milled. How many thousandths would it take to raise compression half a point?
Old Nov 8, 2014 | 08:08 PM
moe7404's Avatar
i found one CR calculator. there are others. but this one is easy to use. ask around as to how much octane that will work with how much CR. https://www.rbracing-rsr.com/compstaticcalc.html ,,,,dont for get the Marvel Mystery Oil. 4 oz to 10 gal gas. my engine starts faster with it. been using it for 30 years.
Old Nov 9, 2014 | 05:31 AM
Cutting .0042" removes 1cc. Head is about 90ccs. Some have removed up to .080".
So, 80thou = 19ccs. 90 minus 19 = 71.
All of this can easily be searched out but buying a modify your Big Block book would be a good purchase.
Removing .010" from head requires .0123" from intake surface.
Did a quick calc. with thin gasket and this would raise compression 1 - 1.5 points.
Forgot to mention, this type of modification with a bigger than stock cam and pistons with no valve notches can get tight and careful clay assembly would be recommended.
Old Nov 9, 2014 | 09:19 AM
I would wait till you could do the whole motor...
Sometimes other issues come up when you start cutting on these heads that much..
Dominic Torreto
Oct 11, 2012 09:10 AM
clint440
Jan 10, 2012 05:29 AM
rward
Apr 3, 2009 01:24 PM
kidcoyotearm
Jan 16, 2009 06:08 PM
EzeakeoRage
Sep 9, 2008 10:29 PM
