Heat in the intake manifold
Old Sep 5, 2014 | 02:51 PM
chargermom's Avatar
We have a 440 that we put a new aluminum intake (Edelbrock performer) on with a new Edelbrock 750 carb. Runs great and no problems starting or running. When we shut it off, the heat gets up into the carb and boils out the gas. We had an older edelbrock carb on it and the gas would boil and leak out a shaft on the passenger side where it would pool for a bit on the intake and then evaporate. The first time we replaced the intake we used an aluminum spacer to prevent the heat from going up to the carb and that burned out quickly. We then switched to a fiber block and that did not burn out, but the heat still goes to the carb shortly after turning off the engine. Any ideas on this for a better way to remove heat when the car shuts off or at least shield the carb so it doesn't boil off whatever is in the carb/fuel filter? Thanks!
Old Sep 5, 2014 | 04:38 PM
The big problem seems to be the gas we have now, IE alcohol. I would block the heat passages in the crossover and definately use a carb insulator. I don't think it matters a heck of a lot what it's made of, as long as you use one. Some guys have even made them out of hardwood
Old Sep 5, 2014 | 05:56 PM
What you can find on the internet.
Thermal Conductivity Rating.
Wood 1.02 Best
Phenolic Resin 2.01
Polymer 3.90
Aluminum 1,665.1
Old Sep 6, 2014 | 01:50 AM
Gorts 5th's Avatar
Smile
Get the insulator spacer from eddel I live I fl.
That spacer works
muggsy
Mar 1, 2011 05:57 PM
THE GOOSE
Sep 6, 2009 06:06 PM
M1 Manifold
May 21, 2009 02:23 PM
scotts74birds
Apr 18, 2009 11:05 AM
Liu Kang
Jan 25, 2009 05:50 PM
