help decoding my 318
Old Jan 30, 2012 | 09:05 PM
mrdeeds's Avatar
hey all
ive looked all over the web to decode what i think is a 318 i bought my b body from a museum in the uk the owner just had her imported but never registered etc. the car was from mexico still has Mexican plates i believe it was assembled in mexico (has a small plate next to the battery reading something about negative battery terminal in Spanish?, the cars had a hard life in the wrong hands at some point due to half of the work done on it lol as you would notice the charger like fuel filler fitted in the photo....
anyhow to my main point ive been through all sorts of decoding mopar engine websites but still a little confused
so far what i have found:
-2bbl
-100% the engine is not original to the car
-it has 318 stamped under the drivers head
-date stamp 15.5.73 so 1973 engine
-727 transmission
-engine has a front sump with the drain plug at the front of the sump also were the drain plug is a square has been cut out of the front subframe to access the drain plug
-drivers side of the engine block near the date stamp under the head just above the starter all i found was this number C30618 if that makes sense to anyone
-passenger side of the engine nothing but a clock of what shift it was built on
another strange thing is the engine mounts have been cut and shaped to fit the engine and bolt to the car?? very bad job
i couldnt find a vin number all i found is a small plate riveted to the door shut of the drivers door under the top door hinge it reads
LA904604
LA9104604
i will get some photos up when i get in from work when i can to show what my issues are im sure someone will be more clued up then i am yet on mopars
any help appreciated
many thanks in advance!
zack
Old Feb 6, 2012 | 03:08 PM
Glad to have you here. I got a full manual for my 1970 from these people.
http://www.autobooksbishko.com/Items...anual/670.html
Won't decode but would help, they may find a more specific one if you contact them.
I live near and work in London Ontario.
Old Feb 6, 2012 | 04:10 PM
We need pictures to figure out what you have ..
Old Feb 8, 2012 | 02:01 PM
mrdeeds's Avatar
awesome thanks guy and i will get a load of hi res photos to help
Old Feb 15, 2012 | 12:58 PM
mrdeeds's Avatar
sorry for the delay guys these are all the number i could find all over the engine
also a photo of the sump dont know if it helps but the subframe has been cut out for the sump plug drain?
Old Feb 15, 2012 | 01:24 PM
mrdeeds's Avatar
also this is the axle fitted to the rear i believe correct me if im wrong its a 9 3/4'' axle normally for 440 magnum 440 six pack and 4 speed hemi's?
Old Feb 15, 2012 | 01:43 PM
I don't know how you are doing pictures but all I see is a red X? Try this for a little picture help.
https://moparforums.com/forums/f62/p...pictures-2128/
Old Feb 15, 2012 | 02:03 PM
mrdeeds's Avatar
ok give me a few mins
Old Feb 15, 2012 | 02:08 PM
mrdeeds's Avatar
any better?
Old Feb 15, 2012 | 02:51 PM
any better?
It just a 318 built in 5-3-73, probably out of a truck because of the front sump oil pan. They cut the front of the K-frame to clearance the oil pan.
Old Feb 15, 2012 | 02:54 PM
Probably not.
Old Feb 16, 2012 | 03:24 AM
mrdeeds's Avatar
the axle looks the same as the last one dose it not?
mrdeeds's Avatar
and thank you for the help
Old Feb 16, 2012 | 03:31 AM
mrdeeds's Avatar
will have to give the axle a good clean and take a better photo
thepickupplace
Cuda Specific Discussion
Jun 29, 2013 09:18 AM
73plymduster
Aug 15, 2010 10:21 AM
plymouth
Aug 5, 2009 01:49 PM
MarkyMark12345
Mar 16, 2009 01:02 PM
70chargerrt
Jun 20, 2008 12:48 AM
