Combo question!
Old Feb 16, 2012 | 08:24 AM
baccaruda's Avatar
Combo question!
What about this combo:
318 std bore,flat head pistons
302 heads ported,
Cam 276/286 duration-441/441 lift
performer rpm intake
Holley 650
Fenderwell headers
2500 stall converter
83/4 -3.10
would that work?
Old Feb 16, 2012 | 09:20 AM
Archer's Avatar
b -
Actually that was kinda close to my old 318.
Anything will "work". That doesn't sound too bad, but your biggest problem will be the 3.10 gears. Great for the highway, but you might find it a little sluggish on the street. Carb is "OK", but you could go a little smaller. (I used to run an 800 cfm Thermoquad, and the very small primaries really helped the bottom end.)
You didn't mention the weight of the car, and that has to factor in.
Old Feb 16, 2012 | 10:38 AM
baccaruda's Avatar
Talking
Originally Posted by Archer
b -
Sorry Archer, i ment 3.91 gear. the carb comes from a chevy 355.
The weight i don't know exactly but it's the car on the pic.
Old Feb 16, 2012 | 11:52 AM
3.55 gear and 600 cfm carb
Old Feb 16, 2012 | 02:43 PM
Sounds close to perfect for a street driver. I might bump the lift up a touch myself. Make sure you check retainer to valve stem clearance for available lift as the stock 318 heads can be tight. Think about a windage tray and oil pan baffling for oil control.
Old Feb 16, 2012 | 04:03 PM
I don't know about the fender well headers The early A bodys did not have much room
Old Feb 16, 2012 | 10:25 PM
baccaruda's Avatar
that's why i have fenderwell. they go up from the heads and down in the wheelhouse.
problem is that i can't mount a bigger brakecylinder...
deadkelly
Aug 30, 2009 07:24 PM
DominicanChallenger
Jun 26, 2009 07:37 AM
71 Duster 440
Jun 13, 2009 02:28 PM
sgoffena
Nov 9, 2007 07:55 PM
moparsforlife
Dec 20, 2006 11:46 PM
