help identify this 5.9L 360
Old Mar 13, 2013 | 07:31 PM
TxDakota5.9's Avatar
I'm new to mopar and I've recently bought a 93 dakota swapped with a 5.9l 360...I looked on the block for the s/n but the number I seen didn't match what I was supposed to look for...supposedly its a crate engine but I'd like to know for sure for parts etc...thanks in advance
Old Mar 13, 2013 | 10:00 PM
jacilynn_s's Avatar
yes its a crate engine from mopar performance. Not sure where that sticker is as I can't make heads or tails of the place or if the picture is upside down.
Usually there is stampings under the drivers side cylinder head on the front of the block.
Old Mar 14, 2013 | 04:03 AM
The first pic is from the block to the bellhousing...second pic is under the cylinder head that's why I was stumped...
Old Mar 14, 2013 | 06:12 AM
PK1's Avatar
PK1
The two crate roller motors, 300HP and 380HP are both truck motors directly from the assembly line. The 300 HP is the entire truck long block with different intake, carb and distributer. Stock had 250 HP due to exhaust manifolds and horrible fuel / timing curve thru a crappy intake.
The 380 has a different cam, springs, intake and distributer. Same truck rotaing assembly. Basically same long block with cam swap.
Block, lifters, valves, rockers, rings, pistons, rods, crank, oil pump, timing chain, bearings etc.. are all OEM production truck.
Pull a valve cover when warm and using a dial micrometer measure the lift at rocker. 300HP has .43 while the 380HP had .501.
Old Mar 14, 2013 | 07:41 AM
Ok will do...also I'm wondering the year I'd be looking for as far as basic parts intake ecu etc or do I just use any year that has the 360 engine...the ecu sticker looks jacked up and I can't tell what it is
Old Mar 14, 2013 | 11:50 AM
PK1's Avatar
PK1
the intakes are same for all magnums. You can use any LA manifold but would need to re drill and tig up the holes.
If the ecu is working use the sct tuners to reprogram. Any tuner can get you going. You will need the ECU number to code in the sct before they ship it.
Old Mar 14, 2013 | 12:43 PM
Yeah the sticker is in bad shape
Hjukke
Jun 26, 2013 09:34 AM
morepar
Sep 9, 2012 06:54 PM
indianfield
Dec 2, 2011 06:49 PM
lynchroad
Jan 20, 2011 01:41 AM
bigdaddy
Jul 2, 2008 05:29 PM
