Help with radiator hose needed
Old May 19, 2018 | 01:31 PM
Vitamin C's Avatar
Don't know where to turn but here.
1970 Road Runner 383 22" radiator
The Mopar part number that looks like will work is 3462114, 3462116 may also work.
http://www.mrmoparts.net/products/up...e-3462114.html
I have an aftermarket one on there now with some numbers but no luck, it currently has an in-line Gano filter I want to get rid of.
Any help would be greatly appreciated.
Old May 19, 2018 | 06:13 PM
Call Charlie... I SELL VERY HIGH QUALITY ALUMINUM RADIATORS, THESE ARE DIRECT BOLT IN, includes AUTOMATIC TRANSMISSION COOLER BUILT IN, & FAN SCROD BRACKETS ARE INCLUDED.
Prices start @ 325.00 + shipping
OTHER CLASSIC MOPAR MECHANICAL PARTS AVAILABLE: ENGINES, TRANSMISSIONS, REAR ENDS, FRONT DISC BRAKE CONVERSIONS, TORSION BARS, FRONT END REBUILD KITS
MOPAR CHARLIE
727-271-5068>>>>>>>
Old May 19, 2018 | 06:30 PM
Vitamin C's Avatar
My radiator is new, just looking for the upper radiator hose.
It's looking like I will have to piece one together..
Old May 20, 2018 | 07:29 AM
Why not just use the Gates radiator hoses?
20370 non-A/C
20630 with-A/C
For some reason I read this wrong.....lol
Old May 20, 2018 | 09:24 AM
Vitamin C's Avatar
The Gates ones from my local parts stores are incorrect and are mostly passenger side input to radiator.
Gates 20630 is passenger side radiator
Gates 20370 is passenger side radiator
Gates 20364 is driver side but does not fit well enough, the 90 down to the T-stat housing is too short.
I called the dealer and the only 3462114 hose left in the country is located in New England.
This is ridiculous, not going to spend that much ($80-90) on a hose, I should be able to find one locally for a stock application.
The hose on my car now has these numbers 5J18 EBP D1 80MH46 MADE IN USA ADS 1119
Old May 20, 2018 | 07:30 PM
Have a look at the 1969 Plymouth Barracuda 383 upper hose... I think they were a drivers side upper hose?
Gates 20386 ????????
Old May 20, 2018 | 08:08 PM
Vitamin C's Avatar
I will see if one of the local stores have one to look at.
Thanks
Old May 23, 2018 | 04:29 AM
ZEN357's Avatar
Have you thought about a Be Cool radiator? You can get one resaonably prices from Jegs or Summit.
Old May 23, 2018 | 08:37 AM
Vitamin C's Avatar
Again, my radiator is a new 4 row, I am not looking for another radiator just so I can get another style radiator hose to fit.
I am just looking for the upper radiator hose, for some reason the ones at the part stores are not compatible and this is a factory application.
No big deal, I am in the process of building one, going to be easier this way.
What I would like is if someone could grab some info (part numbers) from theirs so I can have more info. There has to be another B body out there that has a 383 or 440 with a driver side radiator inlet.
What would be perfect is if I can find a hose that rises from the water neck up 7" to top edge of hose then turn to driver side 9" edge to edge then turn forward to radiator 9" edge to end.
Old May 23, 2018 | 06:38 PM
Vitamin C's Avatar
Well, I looked at the Gates 20386 hose and it would work if my upper radiator inlet was about 4" from center but mine is about 8"
Ordering some of those silicone hoses like HPS or Pegasus have to make one.
Old May 23, 2018 | 08:59 PM
OK... I gave it my best shot !!!!! lol
Hey at least I was close....
Sorry I could not get you closer...
Cant win them all, I guess
Old May 24, 2018 | 10:28 AM
Vitamin C's Avatar
I really appreciate your help on this.
Thanks
Old Jun 2, 2018 | 06:56 AM
Vitamin C's Avatar
Success!!!!
Dayco 70352 fits perfectly!
Old Jun 2, 2018 | 08:49 AM
Wooooo Hoooooo..... Glad you found what you needed.... Dont forget to write that one down in your car note book....
ottosen@chorus.net
Apr 22, 2017 07:33 PM
Myraman
Oct 6, 2013 07:40 AM
cuda 440
Jul 3, 2013 04:35 PM
69Ronrunner
Feb 21, 2013 06:13 AM
Dodge Girl
Sep 13, 2012 09:16 PM
