Holley 4160 on cast 383 intake help
https://cimg3.ibsrv.net/gimg/moparfo...4d9ded578.jpeg
https://cimg5.ibsrv.net/gimg/moparfo...fcbb15d15.jpeg https://cimg6.ibsrv.net/gimg/moparfo...3da86931a.jpeg https://cimg8.ibsrv.net/gimg/moparfo...2e3dc8ee5.jpeg Anyone mount a holley on a stock 4 barrel intake? Got a trans dapt adapter but the ports dont line up well and tech support said run it, its a ‘68 383 newport wondering if anyone has made a better spacer or dealt with this , i should have pictures attached |
I can't say I've seen worse but some of the adapters for the early Chevy 4v carb manifolds are about the same and they seem to work.
(Post 149954)
What do they cal this small pattern style intake? |
Check the 4150 adapter Flange Spec.....
H -
At the risk of fixing a problem that doesn't exist, given the price of aftermarket manifolds (and not forgetting the used market), you might think about a swap and loose a few pounds in the process. Archer |
Originally Posted by Archer
(Post 150107)
H -
