holley fuel regulator
Has anyone had any issues with mounting the regulator on the intake manifold right in front of carb such as vibrations problems,or do you think its better to mount on fenderwell, Thanks Rodger
FYI, be sure to use as much hard-line as possible. Then braided. Dont run this in rubber fuel line! Most track tech allow only "12 of rubber fuel line. My opinion, the less, the better. You are new, so I dont know your skill level. I dont mean to talk down to you if you already know this.
