Horsepower questions
Old Oct 4, 2011 | 08:57 PM
Cazbah362's Avatar
OK guys/gals, I have a few questions. I jsut finished building and dynoing two 440's, here are the specs:
Orage Motor:
KB Quench pistons approx 10.5/1 .30 over
factory rods/steel crank
906 Heads - no porting, slight mill
Crane Cam
M1 with Proform 750 DP
Internal race balance
Factory stamped rockers
Blue Motor:
Ross 10/1 .40 over
H Beam rods/Steel crank
Edelbrock performer heads - no work
Hughes Roller Cam / .517
440 Source roller rockers 1.5
OK, the Orange motor put out 425 HP and 478 TQ. Blue motor put out 460 HP and 508 TQ. Guess I was a bit disappointed, I would have thought the Blue motor would have pulled much more. I know I can do a bit more to get the HP up for the blue, bit the point is the orange motor is a good contender and was a budget build where as the Blue one had a bit more high end parts and only passed 35 more ponies. Any thoughts
Old Oct 5, 2011 | 04:53 AM
Without knowing all the specs, at a glance I'd say it's the camshaft holding back the blue one.
Old Oct 5, 2011 | 10:03 AM
JS23's Avatar
Edelbrock heads. Two thumbs up.
I would think a bit more compression with a roller cam.
Try a one inch space under the carb. It's sometimes surprising what that will do.
Old Oct 5, 2011 | 05:09 PM
PK1's Avatar
PK1
Cam specs on both? Specifically LSA, Duration, installed centerline?
Old Oct 5, 2011 | 06:04 PM
Cazbah362's Avatar
Cam Information
OK, I modified a bit of the items above, I was tired and a bit sick.
As for the spacer, I did use a phenalic 1".
Orange Cam (I initially stated Purple, but it is a crane): http://www.summitracing.com/parts/CRN-680591/
Blue Cam:
LSA: 106
Installed Centerline: 109
Lobe Lift .346 .350
1.5 Intake Exhaust
.519 .525
Duration @50 228 236
Old Oct 5, 2011 | 08:07 PM
Hey Caz, have you thought about 1.6 rockers?
Old Oct 5, 2011 | 08:42 PM
Cazbah362's Avatar
Coronet,
I have. I am thinking hard right now on Harland-Sharps or T&D's, since T&D is right down the road from me. Also, I have a dual quad which I am putting on with two Carters. The M1 was just for the Dyno since I did not plan on tuning or actually putting as much time in as I had. The Blue one is going into my 68 GTX with a 4 speed and 3:55's. Figure I will need to tune it all in/on the car. Don't think the two fours will increase power, thinking it may take a bit away, but chicks will dig it.
I also have the top half off tonight and I am going to double check the degree/timing. Altitude is a PITA, approx 5,000 here, so reading up on what is the better stratagie. Really would of thought the Edlebrock's would have been a bonus, but I feeling they are like putting a pig on Jenny Craig, may be lighter, but they are still pigs
Open to thoughts - but yes, 1.6 are in the future.
SMRE
Dec 3, 2011 11:31 AM
3gknuck
May 16, 2009 01:52 PM
sgp7679
Dec 21, 2008 01:18 PM
hrspwr1
Jun 30, 2008 05:22 AM
AZ-360-Duster
Jan 29, 2008 08:53 AM
