Ignition Timing Issues with 1976 318 with a weind 143 blower
Engine fully Hand built with 8.5 to 1 compression. I haven't Cranked it up yet
as I don't have the Proper ignition system system. Help please! Thank you in advance for all help. |
Ok, what's your question!
If its timing components, MSD. I don't know what else to tell you by your post. |
Ignition Timing Components and Set at What degrees?
Yes. Looking for Components with timing retard.. @10 lbs boost where do I set Ignition Timing? -1° to -2° per 1lbs Boost? Also at what degrees do I set Idle advance with 93 pump gas?
MSD With timing control... Make sure the on you get has start retard... I would as a start, 6* would be safe....
Good luck.. Keep us posted... :) |
