Ignition Timing Issues with 1976 318 with a weind 143 blower
Old Oct 6, 2017 | 10:09 AM
DarrellW's Avatar
Smile Ignition Timing Issues with 1976 318 with a weind 143 blower
Engine fully Hand built with 8.5 to 1 compression. I haven't Cranked it up yet
as I don't have the Proper ignition system system. Help please! Thank you in advance for all help.
Old Oct 6, 2017 | 10:58 AM
Ok, what's your question!
If its timing components, MSD.
I don't know what else to tell you by your post.
Old Oct 6, 2017 | 12:56 PM
DarrellW's Avatar
Ignition Timing Components and Set at What degrees?
Yes. Looking for Components with timing retard.. @10 lbs boost where do I set Ignition Timing? -1° to -2° per 1lbs Boost? Also at what degrees do I set Idle advance with 93 pump gas?
Old Oct 6, 2017 | 02:42 PM
MSD With timing control... Make sure the on you get has start retard... I would as a start, 6* would be safe....
Good luck.. Keep us posted...
Inspector71
Oct 8, 2013 03:24 PM
Gorts 5th
Dec 19, 2012 04:52 PM
a.johansson84
May 27, 2012 03:30 AM
69charger71duster
Mar 3, 2012 12:00 PM
Streetkitcar
Jul 3, 2011 01:59 PM
