Intake manifold air sound
Old Feb 19, 2016 | 11:52 AM
josehf34's Avatar
My car has a 360 SB, I cleaned the engine yesterday and just after finish and start the car, I heard a sound like air leak coming from somewhere around the intake manifold.
I already checked and the sound isn't coming from the carburetor air horn, also, the vacuum gauge shows a decrease in the vacuum signal at idle
I made a video where can hear the sound
Link: http://vid1067.photobucket.com/album...pshafgtjbv.mp4
Old Feb 19, 2016 | 02:20 PM
Archer's Avatar
j -
Well you have a vacuum leak, no surprise there. Take a squirt bottle full of water and spray around where you hear the noise. When the noise changes, you found your leak. Do all the gaskets, connections, etc.
Old Feb 19, 2016 | 02:48 PM
Or break cleaner ,carb cleaner.
Old Feb 20, 2016 | 09:25 PM
fivepoint's Avatar
While you were cleaning, did you disconnect or break a vacuum hose?
Old Feb 20, 2016 | 09:34 PM
fivepoint's Avatar
just watched the video, is your fuel line ok? Looked like it had kink in it.
Old Feb 21, 2016 | 08:52 AM
It should be replaced with a steel line.
Old Feb 24, 2016 | 08:26 AM
DDodger's Avatar
Get a scrap of hose, fuel hose, garden hose, "hose hose". Put up to your ear, and work the end around the manifold and carb while running. You will find it. There's a leak, there, somewhere
Old Mar 1, 2016 | 04:37 PM
josehf34's Avatar
Thanks guys!
I did a quick rebuild and inspection, replaced intake, exhaust, heads gaskets and the sound disappeared
Old Mar 1, 2016 | 07:24 PM
It's nice when things work out!
Dizzle
Sep 16, 2010 09:13 AM
Barfly
May 17, 2010 08:45 PM
CantRamItDodgeIt91
Nov 3, 2009 09:25 PM
M1 Manifold
May 21, 2009 02:23 PM
Yorkie Mama
Apr 7, 2008 11:33 AM
