Intake plate
Old 01-15-2012 | 05:40 PM
Joe's challenger's Avatar
Intake plate
Gang, Another question I found this plate in the passenger side of the intake, nothing attached to it- could it be for the coil? Thanks Joe
Old 01-15-2012 | 06:10 PM
fivepoint's Avatar
Not sure but I think its the choke stove. The factory carb automatic choke coil would fit in the hole beneath the plate. Its where the coil would get heated to eventually open the choke. That plate over the hole may not be original.
Old 01-15-2012 | 06:59 PM
mr340's Avatar
Fivepoint is correct, and the plate is definitely not original.
Old 01-15-2012 | 08:24 PM
fivepoint's Avatar
Is "Choke stove" the correct name for that hole?
Thanks, do I need that covered??
Old 01-15-2012 | 09:06 PM
Called Automatic Choke Well that is open to the heat crossover passage and exhaust gases, needs to be covered. Factory has a gasket then a Stainless Steel Cup that drops in to make a spot for the Thermostatic Coil Spring to fit into. From the spring is a rod that moves up and down to actuate the choke dependent on temperature.
Old 01-15-2012 | 09:11 PM
It's a BB but it It would not matter if it was blocked for the choke. Without knowing what year ? My guess is the EGR port
Old 01-16-2012 | 12:54 AM
It's not EGR, it is in fact the choke well. I don't remember them being open to the crossover either, but maybe the manifold eroded through and leaked?
Old 01-16-2012 | 06:09 AM
Great thanks, from what you told me I was able to find what the automatic looks like and it appears I can block that off if I want? I haven'e use electric chokes for not a need for most of the time, however I may look at it when this build goes. Again thanks Joe.
rcknrolfender79
03-11-2013 08:52 PM
68Barracuda
05-23-2009 06:25 PM
bighammer
04-11-2009 08:24 PM
GOkada
08-02-2008 12:27 PM
David Ridgway
01-24-2008 05:24 AM
