Intake plate
Old Jan 15, 2012 | 04:40 PM
Joe's challenger's Avatar
Intake plate
Gang, Another question I found this plate in the passenger side of the intake, nothing attached to it- could it be for the coil? Thanks Joe
Old Jan 15, 2012 | 05:10 PM
fivepoint's Avatar
Not sure but I think its the choke stove. The factory carb automatic choke coil would fit in the hole beneath the plate. Its where the coil would get heated to eventually open the choke. That plate over the hole may not be original.
Old Jan 15, 2012 | 05:59 PM
mr340's Avatar
Fivepoint is correct, and the plate is definitely not original.
Old Jan 15, 2012 | 07:24 PM
fivepoint's Avatar
Is "Choke stove" the correct name for that hole?
Thanks, do I need that covered??
Old Jan 15, 2012 | 08:06 PM
Called Automatic Choke Well that is open to the heat crossover passage and exhaust gases, needs to be covered. Factory has a gasket then a Stainless Steel Cup that drops in to make a spot for the Thermostatic Coil Spring to fit into. From the spring is a rod that moves up and down to actuate the choke dependent on temperature.
Old Jan 15, 2012 | 08:11 PM
It's a BB but it It would not matter if it was blocked for the choke. Without knowing what year ? My guess is the EGR port
Old Jan 15, 2012 | 11:54 PM
It's not EGR, it is in fact the choke well. I don't remember them being open to the crossover either, but maybe the manifold eroded through and leaked?
Old Jan 16, 2012 | 05:09 AM
Great thanks, from what you told me I was able to find what the automatic looks like and it appears I can block that off if I want? I haven'e use electric chokes for not a need for most of the time, however I may look at it when this build goes. Again thanks Joe.
rcknrolfender79
Mar 11, 2013 07:52 PM
68Barracuda
May 23, 2009 05:25 PM
bighammer
Apr 11, 2009 07:24 PM
GOkada
Aug 2, 2008 11:27 AM
David Ridgway
Jan 24, 2008 04:24 AM
