Just installed a 2" wood phenolic spacer!
Old Jun 5, 2013 | 06:47 PM
inri's Avatar
Oh yeah!
I just replaced the aluminum 2" spacer with a wood-grain phenolic 2" spacer; not the plastic cheap-o one. Took me about 15 minutes; though I anticipated an hour or so. Both gaskets came right off the manifold and carb so I didn't have to do any scrapping.
Tightened down the ARP bolts and reset the carb. Car starts right up and sounds great. Anyway to check to be sure there isn't a leak between the manifold/spacer or the spacer/carb? Just want to be sure everything is right n tight.
Thanks!
Old Jun 5, 2013 | 08:27 PM
No whistling noise from that area and your fine. Spray some water or wd-40 around that area and if the motor doesn't speed up then your good to go. Otherwise put a vacuum guage on it.
Old Jun 6, 2013 | 05:46 AM
Archer's Avatar
inri -
They generally don't leak from the get go.
The leaks start after they get soaked with fuel.
Hang on to the aluminum spacer.
Old Jun 6, 2013 | 06:54 AM
inri's Avatar
Originally Posted by Archer
inri -
I bagged the spacer with the bolts, just in case
champer
Sep 3, 2014 12:15 PM
inri
May 15, 2013 02:19 PM
trivium
Jun 30, 2011 08:26 PM
mytracy
Dec 29, 2010 08:20 PM
mystarcollectorcar.com
Apr 16, 2010 03:42 AM
