Long Ram on a 440
Old Dec 16, 2011 | 08:39 AM
HotRod Heathen's Avatar
Long Ram on a 440
Can anyone tell me if a Long Ram setup from a 1960 413 will fit on a 1970 440?
Old Dec 16, 2011 | 11:45 AM
Mr.Duster's Avatar
it should be able to but dont hold me to it
Old Dec 16, 2011 | 02:18 PM
They are both RB so it will fit the motor. Will it fit the body probably .
Will it be a pain to run and tune YES
Old Dec 16, 2011 | 05:52 PM
MercuryDon's Avatar
It will fit the engine but will not fit in a B Body without cutting the inner fender wells . It will fit C bodies.
Old Dec 16, 2011 | 05:55 PM
Actually the long ram manifolds are two piece and have a rubber hose interconnecting the balance fittings. This means not only will they fit RB, but B engines as well.
Old Dec 16, 2011 | 05:57 PM
MercuryDon's Avatar
Longrams use a metal balance tube to connect the the two boxes under the carbs.
Old Dec 16, 2011 | 08:49 PM
And you point is what, exactly?
The tubes are INTERCONNECTED with rubber hose. This means that they can be used/ adapted to low deck engines, and IN FACT have been
http://www.allpar.com/mopar/sonoramic.html
Old Dec 16, 2011 | 09:02 PM
Allpar is sucking again...MoparForums.com Rule....
Old Dec 23, 2011 | 04:28 PM
MercuryDon's Avatar
My point is you are wrong and giving out false information !
Old Dec 23, 2011 | 07:12 PM
Well "Mercury Don" I suggest you stay with yer Ferds.
These were used on BOTH B and RB engines, and because the balance tube was separate and INTERCONNECTED with rubber hoses, these manifolds CAN BE USED on any big block Mopar engine.
I HAVE personally seen them on BOTH types of engines.
Would you like to bet 10,000 bucks? That seems to be a pretty familiar number, lately.
Old Dec 24, 2011 | 02:44 PM
MercuryDon's Avatar
I never said long Rams could not be used on Low and high deck engines. All I said is there is a metal balance tube and not just hose used. As far as mopars go I have owned/restored upwards of 25-30 of them and have most likely forgotten more than you'll ever know.
Old Dec 25, 2011 | 08:56 AM
blue 68 gts's Avatar
I highly doubt that...
I got into a tiff with 440Roadrunner along time ago, didn't like the guy for a while but got over it.
But this guy, IS SMART. He knows his Mopars... I've learned alot from his posts in the last 4 years, more so then yours.
I can also count a couple posts where I fixed some of your info you gave out because it was false.
Old Dec 25, 2011 | 11:47 AM
MercuryDon's Avatar
Like What ?
Old Jan 3, 2012 | 07:21 AM
deputy169's Avatar
hey don I just joined yesterday, 01/02/2012. I sent you a private message with my tx#. I'm not sure how to navigate through all this as i'm new to all this. If you can please call me have some ???? thanks, deputy 169
t/s1148
Apr 29, 2015 11:09 AM
BoltonDodge
Oct 24, 2014 07:58 PM
maynardc69
Dec 9, 2012 12:34 AM
talulah
Oct 20, 2011 07:06 AM
joe440
Jul 20, 2011 11:53 PM
