Modern engine oils in older engines: Addressing the additive issue
Old 09-03-2011 | 06:35 AM
DartcustomcrusieR's Avatar
Exclamation Modern engine oils in older engines: Addressing the additive issue
I was sitting around drinking with some oldtymers last night and we got to talking about how great the /6 was and the notiriaty so on so forth. One of them being a retired Mechanic started talking about engines of the day and slowly we got around to oils to keep them strong and good to go. So with advice from people whom have been there and done that and personal research. here is what i have for everyone, though the Forum could use something like this. so this post is about modern engine oils in older vehicles! enjoy.
The problem
Zinc and Phosphorus-based extreme-pressure additives known generally as ZDDP have been present in engine oils for many years. Even in minuscule doses, these additives affect the hypersensitive exhaust catalysts used in current ultra-super-mega-low-emission vehicles. These extreme-pressure additives are also, so goes the claim, unnecessary in engines with roller-type valve lifters (i.e., virtually all of them today), which eliminate the sliding-friction junction of camshaft and solid non-roller lifter, which was what the ZDDP was used to lubricate/cushion. The latest API oil service rating for gasoline engines is "SM". The SM standard limits ZDDP to concentrations lower than optimal for our older engines, meaning these new oils give significantly poorer protection of the solid lifter-to-camshaft junction compared to previous spec oils. In everyday terms, the latest engine oils are not slippery enough when it comes to the camshaft-tappet junction.
Some of the heavy duty (diesel-rated) oils are good, but even many of these are moving to the SM service rating. It is only going to get more difficult with time to find SL-rated oils that contain the higher levels of ZDDP.
The solution
Generally, it's a poor idea to pour oil additives or "engine treatments" into your crankcase. Most of them do no good, and many of them can actually do quite a bit of damage. However, the low-ZDDP problem can be addressed successfully and at low cost if the additive is chosen carefully and used in thoughtful proportion. The ZDDP additives are available in the aftermarket. GM offers it as "EOS" (Engine Oil Supplement) under p/n 1052367 in the US, 992869 in Canada, and it seems adding some at each oil change would provide the extreme-pressure protection missing in SM oils without much of any chemical incompatibility risk, and without buying more costly exotic oils.
How much to add?
Well, the SM spec stipulates Zinc and Phosphorus content of 0.06% to 0.08% (600 to 800 ppm). GM EOS contains 5762ppm Zn, and 6221ppm P, or 0.6%. That means in a quart of EOS, you've got about 0.192 ounce of Zn and P. It's been well documented that a 0.10% to 0.12% concentration of Zn and P is optimal for flat-tappet engines, for example in SAE papers 770087, 831760, and 2004-01-2986.
To achieve 0.11% Zn and P in a 5-quart system, we would want 0.176 ounces of Zn and P. There's 0.192 ounce in a quart of EOS, but there's also 0.08% Zn and P in a quart of SM engine oil (actually, most of them run a little on the high side, as it seems, but we'll use the 800 figure). In 5 quarts of SM engine oil, therefore, you've got 0.128 ounce of Zn and P. Therefore, you're a little under 0.05 ounce short of what you want. Doing out the math and remembering that I've been rounding pessimistically, 8 ounces (1 cup, i.e., half a pint) of EOS would bring most any SM engine oil back within the optimal Zn and P content, which means that a quart of EOS would last you four oil changes. A quart of EOS lists for over $9, but can be had for $5.50 or so from a friendly parts department or GM Parts Direct. So, the added cost per oil change would be less than $2, even allowing for shipping charges.
So-called oil "stabilizers" (STP, Lucas, etc.) are mostly just motor snot, the kind that sleazy used-car dealers have been spooning into crankcases to quiet worn engines and temporarily stop exhaust smoke since your grandfather was in the market for his first car.
Old 09-03-2011 | 06:41 AM
ok so ask some other people some questions to make this thread better i would like to know from others on the forum for knowledge.
1. Has anyone ever had success using motocycle oil in there older engines?
2. and instead of the GM parts that i could only find to help this delimma, does anyone know any mopar products that match these specs?
Old 09-03-2011 | 07:37 AM
I use Joe Gibbs Hot Rod oil.
Old 09-03-2011 | 07:42 AM
https://moparforums.com/forums/f62/o...-engines-2333/
Old 09-03-2011 | 08:36 AM
Nice post thanks
Old 09-03-2011 | 11:27 AM
I went to the auto store today and got me 5 quarts of Rotella T 15w-40. I am goin to use this because it has the stuff that was preached about for my old engine. it contains 1200 ppm zinc and 1100 ppm phosphorous and i think this will be money for my /6!
what does joe gibbs have in his and why do you use it?
Old 09-03-2011 | 11:39 AM
Go to there site for the data. I use it because it is a good price and the local speed shop carries it, they also have many different products and grades to match what I'm doing with the engine.
Old 09-03-2011 | 12:09 PM
Seems like some good oil thats designed for a Purpose, i'll keep looking for a chart though if push comes to shove i'll call and ask!
Old 09-03-2011 | 12:35 PM
I called Blake Spee jr. @ Joe Gibbs and he says the Hot Rod Oil has 1300 ppm Zinc and 1200 ppm Phosphorous thats slightly better than Rotella from shell.
I wonder if anyone else has heard any claims of greatness from any other oil brands that can beat these numbers and still provide optimum protection.
Old 09-03-2011 | 08:15 PM
mod381's Avatar
I do not remember the exact numbers but i use brad penn oil.
Old 09-04-2011 | 12:44 PM
1,500 ppm Zinc (Zn) and 1340-1400 ppm Phosphorus acording to the brad penn company.
Now southwest Reasearch, a company outsourced to do these numbers reported brad penn's oils as such.
Penn grade 1 20w-50/ zinc 1,540 ppm, phos 1,319 ppm
Penn grade 1 10w-30/ zinc 1,565 ppm , phos 1,332 ppm
Brad Penn PCMO/ zinc 1,051 ppm, phos 901 ppm
not bad numbers is there a company with better numbers?
Tom T2
08-23-2015 07:21 PM
aubbens
09-12-2012 08:59 PM
fastcoauto
09-11-2012 09:22 AM
runrmc
04-18-2010 05:23 PM
lunarsurface
05-19-2009 09:38 AM
Quick Reply: Modern engine oils in older engines: Addressing the additive issue
