Mopar 360 distributor
Hey guys when i took my distrubtor off i had a metal ring that came off with it and i have lost. Im trying to replace it but cant seem to find a name for the part or find it anywhere. Anybody know what it is or if i even need it?
MUST be installed. I would check if your local dealer has it.. distributor seal ?? Any LA motor same size.
If it's 2 inch I.D. not needed as there should be a groove with O ring that seals to the block when dist pushed down. O ring easy to find.
Is this what your looking for?
Distributor Gasket, Aramid Fiber, Chrysler, Dodge, Plymouth, 318, 340, 360, Part No. C5630-060 https://www.summitracing.com/parts/cgt-c5630-060 https://static.summitracing.com/glob....jpg?rep=False Felpro 6464 may work as well and you local auto part store should be able to order it for you. https://static.summitracing.com/glob....jpg?rep=False |
I had experience with them where the distributor would not seat completely you could see a slight wiggle in the dist when running That's why I recommended replacing it
