Mopar 360 distributor
Old Dec 14, 2017 | 03:23 PM
stokedandstupid's Avatar
Hey guys when i took my distrubtor off i had a metal ring that came off with it and i have lost. Im trying to replace it but cant seem to find a name for the part or find it anywhere. Anybody know what it is or if i even need it?
Old Dec 14, 2017 | 04:59 PM
MUST be installed. I would check if your local dealer has it.. distributor seal ?? Any LA motor same size.
Old Dec 15, 2017 | 02:54 PM
If it's 2 inch I.D. not needed as there should be a groove with O ring that seals to the block when dist pushed down. O ring easy to find.
Old Dec 15, 2017 | 09:55 PM
dodgem880's Avatar
Is this what your looking for?
Distributor Gasket, Aramid Fiber, Chrysler, Dodge, Plymouth, 318, 340, 360,
Part No. C5630-060
https://www.summitracing.com/parts/cgt-c5630-060
Felpro 6464 may work as well and you local auto part store should be able to order it for you.
Old Dec 15, 2017 | 11:46 PM
I had experience with them where the distributor would not seat completely you could see a slight wiggle in the dist when running That's why I recommended replacing it
josehf34
Mar 7, 2016 11:27 AM
dreyerot
Dec 2, 2013 12:48 AM
Mr442
Jul 14, 2013 09:25 PM
wingnutt2420
Jan 8, 2011 10:23 AM
390AMX
Jun 11, 2008 07:28 PM
