My 440 distributor problem
Old Apr 12, 2014 | 12:34 PM
newto440's Avatar
A MOPAR mechanic just finished looking a my 440. Everything checks out i.e. fuel, spark, rocker movement. He replaced the plug wire and it's the same, still missing on ole no. 8. End result: drive it, he did suggest a "leak down" test.
Thanks to everyone for your input.
Old Apr 12, 2014 | 03:07 PM
What did the plug look like ? did he replace the plug ? What happens when you disconnect the plug wire ? Do a compression test !
Old Apr 12, 2014 | 05:17 PM
newto440's Avatar
440 problem
Changed wires and plug. He put a timing light on it, timed it. The compression is 115 on 8, which is within 15 pounds of all the cylinders. The plug was slightly dark, not wet, not white. The plug fired when removed and grounded. We took off the valve cover and he checked out the rocker lifts. Then removed the carb and ran a scope down the runner for no 8, all clear. What next?
Old Apr 12, 2014 | 05:20 PM
newto440's Avatar
440 problems
With the engine running and the plug wire removed the RPM's don't change.
Old Apr 12, 2014 | 06:15 PM
Mr.4spd's Avatar
Intermittent or never fires at all? Has it ever run right since you've owned it? Is that header tube smashed flat? Fuel distribution problem? 115 psi sounds low, that's like less than 8:1...either way I guess the point is all cylinders are in this range and fire just fine. Real mystery.
Old Apr 12, 2014 | 06:34 PM
newto440's Avatar
440 problems
It seems like it doesn't fire at all, it has never run right since I've owned it. I have never had it on the road yet (not counting two trips around the block). It sure seems like a fuel problem, I really can't tell you if it starts firing when the RPM's pick up, I don't have the equipment. It has cast iron exhaust manifolds. This truck has not been on the road or completely assembled in 18 years. Thanks for the interest.
Old Apr 13, 2014 | 07:25 AM
Mr.4spd's Avatar
Maybe the exh manifold is plugged with carbon? Pull the plug and rotate the engine by hand, do both strokes push air out the hole like it's the compression stroke? Or drop a spare working carb on it? Very curious about this.
Old Apr 13, 2014 | 09:45 AM
JS23
Dec 17, 2014 10:13 AM
ottosen@chorus.net
Aug 10, 2013 05:46 PM
Ty Henry
May 24, 2012 06:15 PM
shoreboy85
Aug 17, 2011 08:39 AM
2002ram440
Jun 7, 2010 04:33 PM
