New electric fuel pump
So my mechanical fuel pump finally craped out and I will be replacing it with an electric one and since I am going to be installing it close to the tank I was just going to replace all the fuel line as well but wanted to go to 3/8”. Is it better to use a hard line or will I be ok using a rubber line?
I would NOT use hose unless it is temporary. Use hard line If you are concerned about doing the bends ? Year One/ many other places sells a fuel line come in a 4' circle you have to carefully un curl it.. OR get some 4-6' lengths/ at a parts store with fittings & a coupler and make your own.
Thanks for the input, I will get some hard line and bend it myself. It’s going in a 1978 half ton truck that originally came with an in-line 6. There is NO aftermarket anything for it so I have had to do everything the hard way. I’m using an electric pump because I already have it and wanted to save a little money.
Now I just need to find a good suspension set up.
Keith Roberts
Mar 1, 2017 10:54 AM
chykov's76doba
Mar 25, 2013 09:58 AM
Henrius
Nov 13, 2009 12:36 AM
