New fuel pump not working on a Mopar 440
I have a 1970 GTX with a Mopar 440, I just put a new fuel pump on it, because I thought the pump died, but it's not building fuel pressure, and I noticed that there was no resistance from the cam rod when installing the pump, so I took it back off and watched the cam rod as the car was being cranked, and the rod does move about 1/2 an inch, and I finally found that the cam rod isn't even hitting the fuel pump lever/arm on the new pump, so I tried the old pump and the lever barely hits the cam rod, not enough to pump any pump though.
Any thoughts on what I should do?
Thanks much
Isaiah
Thanks much
Isaiah
All you guys need to get yourself a service manual. You can download many of them free over at MyMopar. The rod comes right out of a B / RB engine, there's an pipe plug, usually allen head, "down there."
Inspect the end of the rod, and if it looks bad, inspect the cam. Inspecting the cam WILL require a tear down.
Frankly, I'd install a rear mount electric pump, which helps control fuel boiling / vapor lock with today's alcoholized fuel
chykov's76doba
03-31-2021 12:07 PM
