No fire after rebuild
Old Jun 18, 2018 | 12:50 PM
mab4962's Avatar
I have a 1973 Plymouth Satellite Sebring which I just put a new engine in - 318 V8. The car was running before I started the swap. New engine (professional rebuild), new wires, plugs, battery, distributor, rotor and cap. The car tuns over but no fire. Any suggestions would be appreciated. Thanks in advance.
Old Jun 18, 2018 | 01:25 PM
Do you have fuel, in the tank and in the carb?
Do you have spark, 12 volts at the coil?
Air, fuel and spark, you need all three.
Old Jun 18, 2018 | 02:26 PM
mab4962's Avatar
I do have gas in the tank. I am using starting fluid until the fuel pump gets gas up the line to the carb. I have no spark from the coil that I can detect (I literally held the wire in my hand as I turned the engine over). How do I check to see if there is 12V going into the coil?
Moparnut1970
Sep 1, 2019 03:38 PM
retrocar66
Dec 21, 2014 03:31 PM
68383camperspecial
Nov 4, 2012 09:18 AM
69dartgirl
May 6, 2012 08:28 PM
silvermopar
Oct 19, 2009 07:43 AM
