Oil Leak Under Back Of Intake
Old Sep 6, 2015 | 06:57 AM
Magoo's Avatar
Question Oil Leak Under Back Of Intake
When I put the Edelbrock Air Gap intake back on to the Edelbrock aluminum heads, I used new side gaskets and Permatex, black, gasket maker, on the ends. Apparently I did not put enough on the back side. I have a SMALL oil leak, at that point. I'd rather not have to take the manifold off, because it sealed real good on the sides - no leaks there. -- I don't know how much pressure is at the back, to push oil out ?? -- Is there a chance that I can clean that area, real good, with lacquer thinner, and run another bead of Permatex, on the outside - push it in, and smooth it with my fingers, and solve the problem, or at least work as a band aid, for a while ?? -- Yes, I know that the real fix is to take the manifold off and start over. -- Thanks
Old Sep 6, 2015 | 08:05 AM
Yes, same as I have done. If your PCV system is working properly under the manifold should stay in a slight vacuum. The oil showing is due to splash and then seepage not from pressure pushing it out.
I would not try and remove any of the existing bead as you may push some in while trying to remove it, which then creates another problem.
Old Sep 6, 2015 | 08:34 AM
Magoo....... You can try that..... Clean it well with brakleen and use the gray stuff. Make a nice bead and let it dry and see if that works... If not... Well you know what needs to get done...
http://www.permatex.com/products-2/p...r-82194-detail
Old Sep 6, 2015 | 09:07 AM
Magoo's Avatar
Thumbs up OIL LEAK
-- Yep - I'm hoping that it works. -- I'll get some gray Permatex, as in the Permatex site. -- Keeping my fingers crossed. -- Thanks
Old Sep 6, 2015 | 09:10 AM
The simple fix is always worth a try, you can always do it correctly if it doesn't work.
Old Sep 6, 2015 | 09:11 AM
Magoo's Avatar
Question WORK ??
--- I assume that it worked. -- ??
Old Sep 6, 2015 | 10:19 AM
Archer's Avatar
Magoo -
Band-aid at best.
It has little to do with pressure, oil will seep through most opening if given half a chance. Ever have a valve cover leak, even right next to the PVC?
If you want a permanent fix you're going to have to do it over. Have sure both surfaces mate and are clean before applying sealer.
Old Sep 6, 2015 | 11:34 AM
Magoo's Avatar
Thumbs up Leak
[QUOTE=Archer;130369]Magoo -
Band-aid at best.
Archer[/QUOTE -- If I force it in, in addition to what is already there, then there should not be an opening. -- Oh well !! -- I'll try it anyway - not like it's a big effort. - I'll take the distributor out and get at it.
Old Sep 6, 2015 | 12:49 PM
Archer's Avatar
Magoo -
Sure it's worth a try ... but if oil was leaking out, that kinda means there's a coating of oil on the walls of the the opening. See the problem ?
Old Sep 6, 2015 | 02:28 PM
Magoo's Avatar
Smile Leak
Originally Posted by Archer
Magoo -
-- We'll find out as soon as I get the ambition to deal with it. -- Thanks
Old Sep 6, 2015 | 03:15 PM
Yes it did work Magoo. I think I used alcohol to clean area and dribbled a bit in through leaking area to clean oil off. Used a tooth pick to mush it in the "crack".
Old Sep 10, 2015 | 10:03 AM
Magoo's Avatar
Thumbs up Looks like it worked
-- Got it done and have driven the car about 200 miles. - No leaks, so far. -- At this point, it has worked.
Old Sep 10, 2015 | 05:49 PM
Glad you got it stopped for now.....
Old Sep 10, 2015 | 06:22 PM
Magoo's Avatar
Smile HOPING
--- Hopefully it's more than for now.
Skynyrd
Sep 10, 2014 05:24 PM
Arth
15
Jun 17, 2014 11:36 AM
Drew Barclay Cambridge
May 20, 2013 04:55 AM
dzltd02
Oct 28, 2008 08:25 AM
robertoil
Jan 25, 2008 05:34 PM
