Please Help :(
Old May 6, 2012 | 06:58 PM
69dartgirl's Avatar
Question Please Help :(
This is the first time I have posted on here and I have a problem with my 1969 Dodge Dart GT..
The engine is a 225 slant 6
My car seems to not want to start at all. It sounds like it's turning over and all but it just won't start up. We rebuilt the distributor there is a new starter a new electronic ignition, and new spark plugs and wires. I'm at a loss at what else to do. If anyone has any ideas please tell me.. :/
Old May 6, 2012 | 07:30 PM
You still have the coil and distributor that could be faulty. There are some good tech videos on youtube. Search for ignition coil testing along with distributor testing. Or Primary igntion system testing.
Old May 6, 2012 | 07:40 PM
69dartgirl's Avatar
We already tested the coil and distributor :/
Old May 6, 2012 | 08:28 PM
MrOldart2U's Avatar
A few more details needed, what modifications if any have been done? And you never stated if it is/was getting spark. It takes spark, fuel, to run. Is it getting fuel? With key off, air cleaner removed, look inside carburetor and operate the throttle linkage looking for a stream of fuel. If not, remove the gas line from carb, place a rubber hose over it, and into a container, and have someone crank engine. If you get a fair stream of fuel then the pump is probably ok. If not the pump maybe out, or the filter is plugged. As first stated a more detail list of items that has been done, to help diagnose the problem.
73plymduster
Aug 15, 2010 10:21 AM
DUST360
Oct 11, 2009 09:54 AM
plymouth
Aug 5, 2009 01:49 PM
Strangeluk
May 26, 2008 10:13 AM
grahamrw2
Jan 16, 2008 03:52 PM
