Really worth to swap to a magnum cylinder head?
Old Oct 8, 2013 | 04:48 PM
josehf34's Avatar
Hi everyone
I always read in forums that If someone has a smog engine one of the best modifications will be to swap the stock LA Cylinder Head to a Magnum Cylinder head due to this one will have best compression and will make best power, best MPG and a smooth ride.
I was looking for a pair of Magnum Cylinder Heads on ebay and they're cheap but I don't find Magnum R/T Cylinder head.
Really worth making this change using the stock pistons?
Old Oct 8, 2013 | 05:00 PM
The heads from the last of the LA engines are good. The magnum heads require more parts than just a swap.. Lifters, push rods, head bolts, change to Magnum intake, rocker arms
Old Oct 8, 2013 | 05:12 PM
josehf34's Avatar
In my case my engine is not one of the last LA engines, mine is a low compression 1974 360 LA. I was thinking about to consider a cylinder head swap in a near future to raise a bit my engine compression and get extra power for my car. So the change will not worth?
EDIT: I was looking at hughesengines web site and they sell magnum cylinder head with LA Bolt Pattern like this also they too sell Edelbrock perfomer intake manifold that fits in Magnum Cylinder head
Old Oct 8, 2013 | 08:42 PM
slade's Avatar
the magnum heads will bolt on but theres more to it than just that. and honsstly i wouldnt waist my time with them. there are far better choices out there. there is no diffrence between a r/t and a normal magnum
Old Oct 8, 2013 | 09:18 PM
Moparbob's Avatar
Like TVLynn said, the last of the LA Heads from around 1990 & 1991 360's & 318's were pretty darn good...I think the last 3 digits of the head castings were "308" on the 360's..... and "302" on the 318's ??
The problem is finding them nowadays, not to mention in re-buildable shape ??
The Cast Iron LA Heads on the Hughes Engines website, I am pretty sure are just Engine Quest Heads, which can be purchased direct over here....
www.enginequest.com
and are in fact for the early LA Engines, part # CH318B with far superior flow & power potential... they use the LA Intake Bolt pattern, however, they do require magnum Style Rockers, check them out here...http://www.aamidwest.com/enginequest...r-magnum-head/
Old Oct 8, 2013 | 09:41 PM
Short of a complete rebuild.. Take your heads off and have .050 cut from them.. Also not sure of the conversion but you need to also cut the intake side of the heads. A repo 340 cam would also help
Old Oct 10, 2013 | 12:30 AM
slade's Avatar
my heads are shaved. 60 lol i needed shims under the rockers. and both sides are ported. add that to a nice cam and intake and u have a good runner
Old Oct 10, 2013 | 11:46 AM
josehf34's Avatar
I already rebuilt my engine but now i want to have a bit more power without affect mpg and I think the best way to do that is to raise a bit the engine compression with new heads and pistons. I dont want to modify my stock heads, i want to change them and keep them stock
I sent an email to hughesperformance people and they recommend me this heads http://www.hughesengines.com/Index/p...=&partid=25739 them looks nice, cheap and I dont need to drill them if im going to use an LA manifold
Old Oct 15, 2013 | 04:41 PM
DodgeAddict's Avatar
If any of you had ever done the Magnum head swap you would be talking differently.
You use Magnum head bolts
You use an aftermarket lifter for a MOPAR (the ones you buy over counter already are oil through)
You use 7.625-7.650 hollow pushrods ($48 at Summit)
You use stock Magnum rockers
You open the pushrod holes a little in the heads
For anything LA to match the performance you have to pay someone to machine them & by parts as well Why Waste the extra $$$$
Hughes sells a bunch of them for this very swap I guess for no reason for they aren't worth the time or the performance gain I don't even know why they take the time to drill the LA pattern on them
Old Oct 15, 2013 | 04:43 PM
I've actually done this swap a few times so I can give an educated answer on it
Old Oct 17, 2013 | 11:16 PM
Aw Snap! I just remembered
You can do roller rockers for the Mag heads (using Chevy rockers) for around $270 shipped to the door
But you have to order 1.6 because that's stock Magnum ratio (LA ratio is 1.5)
Even stock Mag rockers will boost a stock cam a little for more flow
Just a few more reasons why to use them
Old Oct 21, 2013 | 05:03 PM
josehf34's Avatar
Thank you Dodge Adict!
What about this LA Head?
If I'm right the stock LA heads for 1974 has a 84C.C combustion chamber and this one has a 62C.C combustion chamber. I want to do an upgrade to my engine but I want to keep the low rpm torque.
Old Oct 25, 2013 | 05:39 PM
That's all Magnum features with LA oiling & rockers & such
My first Magnum conversion was done using their heads & parts 8 years ago or so
I use a few parts from them when I do Magnum engine conversions
Old Oct 26, 2013 | 02:09 AM
84cc is Big Block territory, most La heads are around 68cc
Old Nov 24, 2013 | 12:09 PM
josehf34's Avatar
I've a question about this two heads:
http://www.hughesengines.com/Index/p...=&partid=27827
Both has a small combustion chamber but one of them has bigger valves so this will give extra horsepower but what will happen with MPG? The logic says that more power equals to lower MPG but what happens if I have more power with the same amount of fuel? i think this is the reality of this ported heads compared to my stock LA heads
Old Nov 24, 2013 | 12:58 PM
PK1's Avatar
PK1
As mentioned above. Not hard.
The LAX (RHS) and EQ casting shouldn't require any pushrod clearance now. You can use any small block gen 1 chevy rocker. ARP makes a 5/16 to 3/8 rocker stud.and add guide plates. Comp use to sell kit 1425-kit that had this conversion all packaged.
Old Nov 25, 2013 | 08:30 PM
josehf34's Avatar
I Think EQ can sell the Heads with all the mounting hardware (they have it on their website). I'll love to have ported heads with the stock camshaft but I'm worried about low rpm torque and MPG. Will be a lot of difference between a ported head and mid ported head?
EDIT: Here's the rocker arms http://www.hughesengines.com/Index/p...0&partid=25405
Old Dec 2, 2013 | 09:14 PM
The rockers are narrow body Small block Chevy (Center bolt heads)
The Comp Cams #'s are as follows for roller rockers
4825-8 for V8's & -10 for V10's Guide plates
4542-16 Studs
1018-16 1.6 ratio rocker arms
7632-16 Hardened Pushrods Roller engine
For a non roller you will need to calculate length & add however much preload on the lifter that you want
Old Mar 31, 2020 | 05:41 PM
Ron Davis's Avatar
Magnum head on La 1972 360
Magnum head on 72 LA 360. I could really use your help I'd like to know if you could tell me what year Magnum head and exact part list so I could try this swap would love to try what you're talkin about
Old Mar 31, 2020 | 08:48 PM
Ron net time you post to a thread try looking at the last posters profile it will tell you waswhen he or she was here last. The member you quoted hasn't been here since Nov of 2015.
71Challengerfan
Feb 5, 2014 07:25 AM
topher0212
Oct 28, 2013 02:24 AM
henryj
Dec 19, 2009 09:21 AM
Stauff73
Oct 2, 2009 03:15 AM
Chuck_S
Jun 25, 2009 09:09 AM
