Removing A/C
Old Jan 22, 2014 | 05:41 PM
Bronze_72newport's Avatar
Removing A/C
Well since the A/C does not blow cold and I do not/would not use it if it did as i like the windows down way better... I want to remove the A/C system. My main question is with the pulleys and belts. If i remove the compressor can I just get a set of pulleys for a engine without A/C? its the 400CI engine. I plan on building the motor anyways so i was already going to replace the pulleys with some lighter/better ones and the belts that are currently on are really old.
if its as simple as that what brand pulleys do you recommend?
68 Sat
Aug 2, 2009 11:52 PM
69Fury3
Jul 26, 2009 09:09 AM
67 GTX
Oct 3, 2008 07:25 PM
71RR08
Aug 12, 2008 10:42 AM
67 GTX
Aug 7, 2008 07:57 PM
