SB HEAD HELP
SB HEAD HELP
Hey guys I am seeking some help/advice with my build.
I purchased a strong running low mile 1987 318 two barrel that i removed from a fifth avenue for $100.
My plan is to put it in a 1937 chevy truck with 4 speed and 8 3/4.
I have a wieand tunnel ram and a few other performance parts i am going to put on it.
I am seeking a better set of heads and have heard lots of rumors as to what to look for at the junk yard. Should I look for 360 heads? Certain year 318 heads? What year vehicle should I be looking for to obtain these heads? Also what size cam should I run? Thanks guys!
Pull off the valve cover and read the casting number, if last 3 digits are 302 be very happy. These are the "swirl port" closed chamber heads. If you put 1.88+ 1.60" valves in with a higher compression height piston you can raise compression have quench and push these to 300-350 HP. With full performance port work and a 1.92" valve 350 HP +.
If you look at a 360 head you'll see open chambers with less compression potential unless you have them milled .050-.060".
Dominic Torreto
Oct 11, 2012 09:10 AM
kidcoyotearm
Jan 16, 2009 06:08 PM
